公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  188粉丝
--- 产品详情 ---
具有 0.8V 至 3.6V 输出、快速瞬态响应和可编程软启动的 3A LDO 稳压器(增强型产品)
Output options Adjustable Output
Iout (Max) (A) 3
Vin (Max) (V) 5.5
Vin (Min) (V) 0.8
Vout (Max) (V) 3.6
Vout (Min) (V) 0.8
Noise (uVrms) 13
Iq (Typ) (mA) 3
Thermal resistance θJA (°C/W) 27
Rating HiRel Enhanced Product
Load capacitance (Min) (μF) 0
Regulated outputs (#) 1
Features Enable, Power good, Soft start
Accuracy (%) 1
PSRR @ 100 KHz (dB) 50
Dropout voltage (Vdo) (Typ) (mV) 115
Operating temperature range (C) -55 to 125
  • Soft-Start (SS) Pin Provides a Linear Startup with Ramp Time Set by External Capacitor
  • 1% Accuracy Over Line, Load, and Temperature
  • Supports Input Voltages as Low as 0.9 V with External Bias Supply
  • Adjustable Output (0.8 V to 3.6 V)
  • Ultra-Low Dropout: 115 mV at 3.0 A (typ)
  • Stable with Any or No Output Capacitor
  • Excellent Transient Response
  • Available in 5 mm × 5 mm × 1 mm QFN Package
  • Active High Enable
  • SUPPORTS DEFENSE, AEROSPACE, AND MEDICAL APPLICATIONS
    • Controlled Baseline
    • One Assembly/Test Site
    • One Fabrication Site
    • Available in Military (–55°C/125°C) Temperature Ranges(1)
    • Extended Product Life Cycle
    • Extended Product-Change Notification
    • Product Traceability
  • APPLICATIONS
    • FPGA Applications
    • DSP Core and I/O Voltages
    • Post-Regulation Applications
    • Applications with Special Start-Up Time or Sequencing Requirements
    • Hot-Swap and Inrush Controls
(1) Custom temperature ranges available
All other trademarks are the property of their respective owners
The TPS74401 low-dropout (LDO) linear regulator provides an easy-to-use robust power management solution for a wide variety of applications. User-programmable soft-start minimizes stress on the input power source by reducing capacitive inrush current on start-up. The soft-start is monotonic and well-suited for powering many different types of processors and ASICs. The enable input and power-good output allow easy sequencing with external regulators. This complete flexibility permits the user to configure a solution that will meet the sequencing requirements of FPGAs, DSPs, and other applications with specific start-up requirements.
A precision reference and error amplifier deliver 1% accuracy over load, line, temperature, and process. Each LDO is stable with low-cost ceramic output capacitors and the device is fully specified from –55°C to 125°C.
