公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  188粉丝
--- 产品详情 ---
高温超低功耗 100mA 低压差线性稳压器
Output options Adjustable Output
Iout (Max) (A) 0.1
Vin (Max) (V) 10
Vin (Min) (V) 5
Vout (Max) (V) 4.5
Vout (Min) (V) 1.2
Fixed output options (V) 0
Noise (uVrms) 190
Iq (Typ) (mA) 0.017
Thermal resistance θJA (°C/W) 259
Rating High Temp
Load capacitance (Min) (μF) 4.7
Regulated outputs (#) 1
Features Enable
Accuracy (%) 3
PSRR @ 100 KHz (dB) 27
Dropout voltage (Vdo) (Typ) (mV) 71
Operating temperature range (C) -55 to 175, -55 to 210
  • 100-mA Low-Dropout Regulator
  • Available in Adjustable Versions
  • Only 335-μA Quiescent Current With 100 mA
    at 210°C
  • 1-μA Quiescent Current in Standby Mode
  • Dropout Voltage Typically 71 mV at 100 mA
  • Over Current Limitation
  • APPLICATIONS
    • Down-Hole Drilling
    • High Temperature Environments
  • APPLICATIONS
    • Controlled Baseline
    • One Assembly/Test Site
    • One Fabrication Site
    • Available in Extreme (–55°C/210°C)
      Temperature Range(1)
    • Extended Product Life Cycle
    • Extended Product-Change Notification
    • Product Traceability
    • Texas Instruments’ high temperature products
      utilize highly optimized silicon (die) solutions
      with design and process enhancements to maximize
      performance over extended temperatures.
(1) Custom temperature ranges available
The TPS76901 low-dropout (LDO) voltage regulator offers the benefits of low dropout voltage, ultralow-power operation, and miniaturized packaging. This regulator features low dropout voltages and ultralow quiescent current compared to conventional LDO regulators. The TPS76901 is ideal for micropower operations and where board space is at a premium.
A combination of new circuit design and process innovation has enabled the usual PNP pass transistor to be replaced by a PMOS pass element. Because the PMOS pass element behaves as a low-value resistor, the dropout voltage is very low, and is directly proportional to the load current. Since the PMOS pass element is a voltage-driven device, the quiescent current is ultralow (28 μA maximum) and is stable over the entire range of output load current (0 mA to 100 mA). Intended for use in portable systems such as laptops and cellular phones, the ultralow-dropout voltage feature and ultralow-power operation result in a significant increase in system battery operating life.
The TPS76901 also features a logic-enabled sleep mode to shut down the regulator, reducing quiescent current to 1 μA, typical at TJ = 25°C. The TPS76901 is a variable version programmable over the range of 1.2 V to 4.5 V).
