公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  190粉丝
--- 产品详情 ---
具有反向电流保护功能的汽车类 50mA、电池供电运行 (50V)、低压降稳压器
Output options Adjustable Output, Fixed Output
Iout (Max) (A) 0.05
Vin (Max) (V) 50
Vin (Min) (V) 3
Vout (Max) (V) 28
Vout (Min) (V) 1.275
Fixed output options (V) 5
Noise (uVrms) 100
Iq (Typ) (mA) 0.04
Thermal resistance θJA (°C/W) 57
Rating Automotive
Load capacitance (Min) (μF) 1
Regulated outputs (#) 1
Features Enable, Reverse current protection, Reverse voltage protection, Short-to-battery protection
Accuracy (%) 3
PSRR @ 100 KHz (dB) 36
Dropout voltage (Vdo) (Typ) (mV) 300
Operating temperature range (C) -40 to 125
  • Qualified for Automotive Applications
  • Wide Input Voltage Range: 3 V to 50 V
  • Low Quiescent Current: 40 μA (Typical)
  • Low Dropout Voltage: 300 mV (Typical)
  • Output Current: 50 mA
  • No Input Protection Diodes Needed
  • Adjustable Output From 1.275 V to 28 V
  • 1-μA Quiescent Current in Shutdown
  • Stable With 1-μF Output Capacitor
  • Stable With Aluminum, Tantalum, or Ceramic
    Capacitors
  • Reverse Input-Battery Protection
  • Reverse Output Current Flow Protection
  • Thermal Limiting
  • Available in an 8-Pin MSOP-PowerPAD IC
    Package
The TPS798xx-Q1 is the first device in a line of 50-V high-voltage micropower low-dropout (LDO) linear regulators. This device is capable of supplying 50-mA output current with a dropout voltage of only 300mV. Designed for low quiescent current high voltage (50 V) applications, 40 μA operating and 1μA in shutdown makes the TPS798xx-Q1 an ideal choice for battery-powered or high-voltage systems. Quiescent current is also well-controlled in dropout.
Other features of the TPS798xx-Q1 include the ability to operate with low equivalent series resistance (ESR) ceramic output capacitors. This device is stable with only 1 μF on the output; most older devices require from 10-μF to 100-μF tantalum capacitors for stability. Small ceramic capacitors can be used without the necessary addition of ESR, as is common with other regulators. Internal protection circuitry includes reverse input-battery protection, reverse output current protection, current limiting, and thermal limiting to protect the device in various fault conditions.
This device is available in a fixed output voltage of 5 V (TPS79850) and with an adjustable output voltage with a 1.275-V reference voltage (TPS79801). The TPS798xx-Q1 regulator is available in a 8-pin MSOP-PowerPAD (DGN) package with an exposed pad for enhanced thermal management capability.
