公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  188粉丝
--- 产品详情 ---
具有使能功能的 800mA、可调节低压降稳压器
Output options Adjustable Output
Iout (Max) (A) 0.8
Vin (Max) (V) 5.5
Vin (Min) (V) 2.25
Vout (Max) (V) 5
Vout (Min) (V) 0.5
Noise (uVrms) 25
Iq (Typ) (mA) 7.5
Thermal resistance θJA (°C/W) 67
Rating Catalog
Load capacitance (Min) (μF) 10
Regulated outputs (#) 1
Features Enable
Accuracy (%) 2
PSRR @ 100 KHz (dB) 30
Dropout voltage (Vdo) (Typ) (mV) 250
Operating temperature range (C) -40 to 125
  • 2.25V to 5.5V Input Voltage Range
  • Adjustable Output Voltage Range of 0.5V to 3.3V
  • 800mA Output Load Current
  • ±2.0% Accuracy over Line, Load, and Full-Temperature Range from -40°C to +125°C
  • Stable with Tiny 10 uF Ceramic Capacitors
  • Enable Pin
  • Typically Less than 1uA of Ground Pin Current with Enable Pin Low
  • 25dB of PSRR at 100 kHz
  • Over-Temperature and Over-Current Protection
  • 8-Pin SO PowerPad and 5-Pin PFM Surface Mount Packages
All trademarks are the property of their respective owners.
The LP38511-ADJ Fast-Transient Response Low-Dropout Voltage Regulator offers the highest-performance in meeting AC and DC accuracy requirements for powering Digital Cores. The LP38511-ADJ uses a proprietary control loop that enables extremely fast response to change in line conditions and load demands. Output Voltage DC accuracy is specified at 2.5% over line, load and full temperature range from -40°C to +125°C. The LP38511-ADJ is designed for inputs from the 2.5V, 3.3V, and 5.0V rail, is stable with 10 uF ceramic capacitors, and has an adjustable output voltage. The LP38511-ADJ provides excellent transient performance to meet the demand of high performance digital core ASICs, DSPs, and FPGAs found in highly-intensive applications such as servers, routers/switches, and base stations.
