Output options | Fixed Output |
Iout (Max) (A) | 0.1 |
Vin (Max) (V) | 28 |
Vin (Min) (V) | 4.5 |
Vout (Max) (V) | 3.3 |
Vout (Min) (V) | 3.3 |
Fixed output options (V) | 3.3, 5 |
Iq (Typ) (mA) | 0.0354 |
Thermal resistance θJA (°C/W) | 80 |
Rating | Catalog |
Load capacitance (Min) (μF) | 10 |
Regulated outputs (#) | 3 |
Features | Enable |
Accuracy (%) | 4 |
Dropout voltage (Vdo) (Typ) (mV) | 400 |
Operating temperature range (C) | -40 to 85 |
- Wide Input Voltage Range: 4.5 V to 28 V
- 5-V/3.3-V, 100-mA, LDO Output
- Glitch Free Switch Over Circuit
- Always-On 3.3-V, 5-mA LDO Output for RTC
- 250 kHz Clock Output for Charge Pump
- Thermal Shutdown (Non-latch)
- 10Ld QFN (DRC) Package
- APPLICATIONS
- Notebook Computers
- Mobile Digital Consumer Products
The TPS51103 integrates three LDOs. The 5-V and 3.3-V LDOs are both rated at 100 mA and also include a glitch-free switch-over feature allowing for optimized battery life. An additional 3.3-V LDO is designed to provide an always on power output for the real time clock (RTC). The TPS51103 integrates a clock output to use with an external charge pump. The TPS51103 offers an innovative solution for optimizing the complex and multiple power rails typically found in a Notebook Computer. The TPS51103 is available in the 10-pin QFN package and is specified from ?40°C to 85°C.
