公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  188粉丝
--- 产品详情 ---
具有使能功能的汽车类 200mA、低 IQ、低压降稳压器
Output options Fixed Output
Iout (Max) (A) 0.2
Vin (Max) (V) 6.5
Vin (Min) (V) 2.7
Vout (Max) (V) 6.4
Vout (Min) (V) 1.2
Fixed output options (V) 1.2, 1.5, 1.8, 2.5, 2.7, 3.3
Noise (uVrms) 30
Iq (Typ) (mA) 0.04
Thermal resistance θJA (°C/W) 74
Rating Automotive
Load capacitance (Min) (μF) 2
Regulated outputs (#) 1
Features Enable
Accuracy (%) 2
PSRR @ 100 KHz (dB) 38
Dropout voltage (Vdo) (Typ) (mV) 100
Operating temperature range (C) -40 to 125
  • Qualified for Automotive Applications
  • 200-mA Low-Dropout (LDO) Regulator
    WithEnable(EN)
  • Low IQ: 40μA
  • Multiple Output Voltage Versions Available:
    • Fixed Outputs of 1.2V to 4.5V
    • Adjustable Outputs from 1.2V to 6.5V
  • High PSRR: 66dB at 1kHz, 51 db at 10 kHz
  • Ultralow Noise: 29.5μVRMS
  • Fast Start-Up Time: 45μs
  • Stable With a Low ESR, 2-μF (Typical) Output
    Capacitance
  • Excellent Load and Line Transient Response
  • 2% Overall Accuracy (Load, Line, and
    Temperature)
  • Very Low Dropout: 100mV
  • Thin SOT-23 and 2-mm × 2-mm SON-6 Packages
The TPS799xx-Q1 family of low-dropout (LDO) low-power linear regulators offers excellent AC performance with very low ground current. High power-supply rejection ratio (PSRR), low noise, fast start-up, and excellent line and load transient response are provided while consuming a very low 40-μA (typical) ground current. The TPS799xx-Q1 is stable with ceramic capacitors and uses an advanced BiCMOS fabrication process to yield a dropout voltage of 100mV(typical) at 200-mA output. The TPS799xx-Q1 uses a precision voltage reference and feedback loop to achieve overall accuracy of 2% over all load, line, process, and temperature variations. It is fully specified from TJ = ?40°C to 125°C and is offered in low profile thin SOT-23 and 2-mm × 2-mm SON packages, ideal for wireless handsets and WLAN cards.
