公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  188粉丝
--- 产品详情 ---
具有使能功能的 200mA、低噪声、高精度、双通道低压降稳压器
Output options Dual Output, Fixed Output
Iout (Max) (A) 0.2
Vin (Max) (V) 5.5
Vin (Min) (V) 1.8
Vout (Max) (V) 2.8
Vout (Min) (V) 1.2
Fixed output options (V) 1.2, 2.7, 2.8
Noise (uVrms) 6
Iq (Typ) (mA) 0.085
Thermal resistance θJA (°C/W) 140
Rating Catalog
Load capacitance (Min) (μF) 1
Regulated outputs (#) 2
Features Enable
Accuracy (%) 1
PSRR @ 100 KHz (dB) 45
Dropout voltage (Vdo) (Typ) (mV) 110
Operating temperature range (C) -40 to 125
  • Input Voltage Operation: 1.8 V to 5.5 V
  • Output Voltage: 1.2 V to 3.6 V
  • Accuracy Over Temperature: 1%
  • Output Voltage Noise: 6 μVRMS
  • PSRR: 75 dB at 1 kHz
  • Dropout: 110 mV at 200 mA Load
  • Quiescent Current: 48 μA per Regulator
  • Start-Up Time: 80 μs
  • Stable With Ceramic Capacitors as Small as 0402
  • Thermal-Overload and Short-Circuit Protection
The LP8900 is a dual LDO capable of supplying 200-mA output current per regulator. Designed to meet the requirements of RF and analog circuits, the LP8900 provides low device noise, high PSRR, low quiescent current, and superior line transient response figures.
Using new innovative design techniques, the LP8900 offers class-leading device noise performance without a noise bypass capacitor.
The LP8900 is designed to be stable with space saving ceramic capacitors as small as 0402 case size, enabling a solution size < 4 mm2. Performance is specified for a –40°C to +125°C junction temperature range.
Output voltage options from 1.2 V to 3.6 V are available; for availability, contact your local TI sales office.
For all available packages, see the orderable addendum at the end of the data sheet.
