Output options | Adjustable Output |
Iout (Max) (A) | 0.5 |
Vin (Max) (V) | 16 |
Vin (Min) (V) | 2.5 |
Vout (Max) (V) | 6.5 |
Vout (Min) (V) | 1.3 |
Noise (uVrms) | 300 |
Iq (Typ) (mA) | 8 |
Thermal resistance θJA (°C/W) | 116 |
Rating | Catalog |
Load capacitance (Min) (μF) | 2.2 |
Regulated outputs (#) | 1 |
Features | Reverse voltage protection |
Accuracy (%) | 2 |
PSRR @ 100 KHz (dB) | 30 |
Dropout voltage (Vdo) (Typ) (mV) | 500 |
Operating temperature range (C) | -40 to 125 |
- Adjustable Output Voltage
- 1%/2% Accuracy (25°C/Full Range)
- 500-mV (Maximum) Dropout at Full Load of
500mA - Tight Regulation Overtemperature Range
- 0.1%/V (Maximum) Line Regulation
- 0.7% (Maximum) Load Regulation
- Ultra Low-Noise Capability (300nV/√HzTypical)
- Shutdown Current of 3μA (Maximum)
- Low Temperature Coefficient
- Current Limiting and Thermal Protection
- Stable With Minimum Load of 1mA
- Reverse-Battery Protection
- Applications
- Portable Applications (PDAs, Laptops,
CellPhones) - Consumer Electronics
- Post-Regulation for SMPS
- Available in Convenient SOIC-8 Surface-Mount
Package
The TL5209 device is 500-mA low-dropout (LDO) regulator that is well suited for portable applications. It has a lower quiescent current than most traditional PNP regulators and allows for a shutdown current of 0.05 μA (typical). The TL5209 also has very good dropout voltage characteristics, requiring a maximum dropout of 10 mV at light loads and 500mV at full load. In addition, the LDO also has a 1% output voltage accuracy and very tight line and load regulation that is comparable to its CMOS counterparts.
For noise-sensitive applications, the TL5209 allows for low-noise capability through an external bypass capacitor connected to the BYP pin, which reduces the output noise of the regulator. Other features include current limiting, thermal shutdown, reverse-battery protection, and low temperature coefficient.
The TL5209 is available with adjustable output. Offered in an SOIC-8 surface-mount package, the TL5209 is characterized for operation over the virtual junction temperature ranges of ?40°C to 125°C.
