公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  188粉丝
--- 产品详情 ---
具有复位延迟功能的汽车类 450mA、电池供电运行 (42V)、低压降稳压器
Output options Fixed Output
Iout (Max) (A) 0.45
Vin (Max) (V) 42
Vin (Min) (V) 5.5
Vout (Max) (V) 5
Vout (Min) (V) 5
Fixed output options (V) 5
Iq (Typ) (mA) 5
Thermal resistance θJA (°C/W) 33
Rating Automotive
Load capacitance (Min) (μF) 10
Regulated outputs (#) 1
Features Power good, Reverse voltage protection
Accuracy (%) 2
PSRR @ 100 KHz (dB) 27
Dropout voltage (Vdo) (Typ) (mV) 250
Operating temperature range (C) -40 to 125
  • Qualified for Automotive Applications
  • Output Voltage 5 V ± 2%
  • Very Low Current Consumption
  • Power-On and Undervoltage Reset
  • Reset Low-Level Output Voltage < 1 V
  • Very Low Dropout Voltage
  • Short-Circuit Proof
  • Reverse-Polarity Proof
The TLE4275 is a monolithic integrated low-dropout voltage regulator offered in a 5-pin TO package. The device regulates an input voltage up to 45 V to VOUT = 5 V (typ). The device can drive loads up to 450 mA and is short-circuit proof. At overtemperature, the incorporated temperature protection turns off the TLE4275. The device generates a reset signal for an output voltage, VOUT,rt, of 4.65 V (typ). By the use of an external delay capacitor, one can program the reset delay time.
The input capacitor, CIN, compensates for line fluctuation. Using a resistor of approximately 1 Ω in series with CIN dampens the oscillation of input inductance and input capacitance. The output capacitor, COUT, stabilizes the regulation circuit. The specification for stability is at COUT≥22μF and ESR≤5Ω, within the operating temperature range. Stability for electrolytic capacitors specifically is at COUT ≥ 68 μF within the operating temperature range. See the application report on low-temperature stability, SLVA501, for further details.
The control amplifier compares a reference voltage to a voltage that is proportional to the output voltage and drives the base of the series transistor through a buffer. Saturation control as a function of the load current prevents any oversaturation of the power element. The device also incorporates a number of internal circuits for protection against: Overload, Overtemperature, and Reverse Polarity.
