公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
具有使能功能的 200mA、低 IQ、高精度、低压降稳压器
Output options Fixed Output
Iout (Max) (A) 0.2
Vin (Max) (V) 5.5
Vin (Min) (V) 2.2
Vout (Max) (V) 3.6
Vout (Min) (V) 1.2
Fixed output options (V) 1.2, 1.3, 1.8, 2.8, 3, 3.3, 3.6
Noise (uVrms) 60
Iq (Typ) (mA) 0.03
Thermal resistance θJA (°C/W) 101
Rating Catalog
Load capacitance (Min) (μF) 1
Regulated outputs (#) 1
Features Enable
Accuracy (%) 2
PSRR @ 100 KHz (dB) 33
Dropout voltage (Vdo) (Typ) (mV) 160
Operating temperature range (C) -40 to 125
  • Operation from 2.2V to 5.5V input
  • ±1% accuracy over temp range
  • Output voltage from 0.8V to 3.6V in 50mV increments
  • 30 μA Quiescent current (enabled)
  • 10nA Quiescent current (disabled)
  • 160mV dropout at 200mA load
  • 60 μVRMSOutput voltage noise
  • 60 μs start-up time
  • 500μs shut-down time
  • PSRR 55 dB at 10 kHz
  • Stable with 0402 1.0μF ceramic capacitors
  • Logic controlled enable
  • Thermal–overload and short–circuit protection
  • Package
    4-Bump micro SMD,0.4mm pitch (lead free) 866 μm x 917 μm
    The LP5990 regulator is designed to meet the requirements of portable, battery-powered systems providing an accurate output voltage, low noise and low quiescent current.
    The LP5990 will provide a 1.8V output from a low input voltage of 2.2V and can provide 200mA to an external load.
    When switched into shutdown mode via a logic signal at the enable pin, the power consumption is reduced to virtually
    zero.
    Fast shut-down is achieved by the push pull architecture.
    The LP5990 is designed to be stable with space saving 0402 ceramic capacitors as small as 1μF, this gives an overall solution size of < 2.5mm 2.
    Performance is specified for a -40°C to 125°C junction temperature range.
    The device is available in micro SMD Package (0.4mm pitch) and is available with 1.2V,1.3V,1.8V,2.8V,3.0V,3.3V and 3.6V outputs.Lower voltage options down to 0.8V are available on request. For all other output voltage options please contact your local NSC sales office.
