公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
具有使能功能的 200mA、负电压、可调节低压降稳压器
Output options Adjustable Output, Fixed Output, Negative Output
Iout (Max) (A) 0.2
Vin (Max) (V) -2.7
Vin (Min) (V) -10
Vout (Max) (V) -1.2
Vout (Min) (V) -9.75
Fixed output options (V) -2.5
Noise (uVrms) 60
Iq (Typ) (mA) 0.13
Thermal resistance θJA (°C/W) 195
Rating Catalog
Load capacitance (Min) (μF) 2.2
Regulated outputs (#) 1
Features Enable
Accuracy (%) 2
PSRR @ 100 KHz (dB) 48
Dropout voltage (Vdo) (Typ) (mV) 280
Operating temperature range (C) -40 to 125
  • Ultralow noise: 60 μVRMS typical
  • High PSRR: 65 dB typical at 1 kHz
  • Low dropout voltage: 280 mV typical at 200 mA, 2.5 V
  • Available in –2.5-V and adjustable (–1.2 V to –10V) versions
  • Stable with a 2.2-μF ceramic output capacitor
  • Less than 2-μA typical quiescent current in shutdown mode
  • 2% overall accuracy
    (line, load, temperature)
  • Thermal and over-current protection
  • Packages:
    • SOT23-5 (DBV)
    • SOT23-5 (DDC)
    • WSON-6 (DRV)
  • Operating junction temperature range: –40°C to 125°C
The TPS723 low-dropout (LDO) negative voltage regulator offers an ideal combination of features to support low noise applications. This device is capable of operating with input voltages from –10 V to –2.7 V, and support outputs from –10 V to –1.2 V. This regulator is stable with small, low-cost ceramic capacitors, and include enable (EN) and noise reduction (NR) functions. Thermal short-circuit and over-current protections are provided by internal detection and shutdown logic. High PSRR (65 dB at 1kHz) and low noise (60 μVRMS) make the TPS723 ideal for low-noise applications.
The TPS723 uses a precision voltage reference to achieve 2% overall accuracy over load, line, and temperature variations. Available in a small SOT23-5 package, the TPS723 is fully specified over a temperature range of –40°C to 125°C.
