公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
具有使能功能的 1.5A、可调节低压降稳压器
Output options Adjustable Output
Iout (Max) (A) 1.5
Vin (Max) (V) 7
Vin (Min) (V) 2.5
Vout (Max) (V) 6.4
Vout (Min) (V) 1.2
Noise (uVrms) 100
Iq (Typ) (mA) 6
Thermal resistance θJA (°C/W) 40
Rating Catalog
Load capacitance (Min) (μF) 10
Regulated outputs (#) 1
Features Enable
Accuracy (%) 4
Dropout voltage (Vdo) (Typ) (mV) 380
Operating temperature range (C) -40 to 125
  • Input Voltage Range: 2.5 V to 7 V
  • Ultra Low Dropout Voltage
  • Low Ground Pin Current
  • Load Regulation of 0.06%
  • 10-nA Quiescent Current in Shutdown Mode
  • Specified Output Current of 1.5-A DC
  • Minimum Output Capacitor Requirements
  • Overtemperature/Overcurrent Protection
  • ?40°C to +125°C Junction Temperature Range
  • Available in DDPAK/TO-263 and SOT-223 Packages
The LP3875-ADJ fast ultra-low-dropout LDO operates from a 2.5-V to 7-V input supply. This ultra-low-dropout LDO responds very quickly to step changes in load, which makes it suitable for low-voltage microprocessor applications. The LP3875-ADJ is developed on a CMOS process, which allows low quiescent-current operation independent of output load current. This CMOS process also allows the LP3875-ADJ to operate under extremely low dropout conditions.
  • Dropout Voltage: Ultra-low-dropout voltage; typically 38 mV at 150-mA load current and 380 mV at 1.5-A load current.
  • Ground Pin Current: Typically 6 mA at 1.5-A load current.
  • Shutdown Mode: Typically 10-nA quiescent current when the SD pin is pulled low.
  • Adjustable Output Voltage: The output voltage may be programmed via two external resistors.
For all available packages, see the orderable addendum at the end of the data sheet.
