Output options | Adjustable Output |
Iout (Max) (A) | 0.8 |
Vin (Max) (V) | 7 |
Vin (Min) (V) | 2.5 |
Vout (Max) (V) | 6.6 |
Vout (Min) (V) | 1.2 |
Noise (uVrms) | 100 |
Iq (Typ) (mA) | 6 |
Thermal resistance θJA (°C/W) | 60 |
Rating | Catalog |
Load capacitance (Min) (μF) | 10 |
Regulated outputs (#) | 1 |
Features | Enable |
Accuracy (%) | 2 |
Dropout voltage (Vdo) (Typ) (mV) | 240 |
Operating temperature range (C) | -40 to 125 |
- Ultra Low Dropout Voltage
- Low Ground Pin Current
- Load Regulation of 0.04%
- 10nA Quiescent Current in Shutdown Mode
- Specified Output Current of 0.8A DC
- Available in DDPAK/TO-263, TO-220 and SOT-223 Packages
- Minimum Output Capacitor Requirements
- Overtemperature/Overcurrent Protection
- ?40°C to +125°C Junction Temperature Range
All trademarks are the property of their respective owners.
The LP3874-ADJ fast ultra low-dropout linear regulators operate from a +2.5V to +7.0V input supply. These ultra low dropout linear regulators respond very quickly to step changes in load, which makes them suitable for low voltage microprocessor applications. The LP3874-ADJ is developed on a CMOS process which allows low quiescent current operation independent of output load current. This CMOS process also allows the LP3874-ADJ to operate under extremely low dropout conditions.
Dropout Voltage: Ultra low dropout voltage; typically 24mV at 80mA load current and 240mV at 0.8A load current.
Ground Pin Current: Typically 6mA at 0.8A load current.
Shutdown Mode: Typically 10nA quiescent current when the shutdown pin is pulled low.
Adjustable Output Voltage: The output voltage may be programmed via two external resistors.
