公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
具有使能功能的 1.5A、7V、超低压降稳压器
Output options Fixed Output
Iout (Max) (A) 1.5
Vin (Max) (V) 7
Vin (Min) (V) 2.5
Vout (Max) (V) 5
Vout (Min) (V) 1.8
Fixed output options (V) 1.8, 2.5, 3.3, 5
Noise (uVrms) 100
Iq (Typ) (mA) 4
Thermal resistance θJA (°C/W) 32
Rating Catalog
Load capacitance (Min) (μF) 10
Regulated outputs (#) 1
Features Enable
Accuracy (%) 2
Dropout voltage (Vdo) (Typ) (mV) 240
Operating temperature range (C) -40 to 125
  • Input Supply Voltage: 2.5 V to 7 V
  • Ultra-Low Dropout Voltage
  • Stable with Selected Ceramic Capacitors
  • Low Ground-Pin Current
  • Load Regulation of 0.06%
  • 10-nA Quiescent Current in Shutdown Mode
  • Specified Output Current of 1.5 A DC
  • Output Voltage Accuracy ± 1.5%
  • ERROR Pin Indicates Output Status
  • SENSE Option Improves Load Regulation
  • Overtemperature/Overcurrent Protection
  • ?40°C to 125°C Junction Temperature Range
The LP3852 and LP3855 series of fast ultra-low dropout linear regulators operate from a 2.5-V to 7-V input supply. A wide range of preset output voltage options are available. These ultra-low dropout linear regulators respond very quickly to step changes in load, which makes them suitable for low voltage microprocessor applications. The LP3852 and LP3855 are developed on a CMOS process which allows low quiescent-current operation independent of output load current, typically 4 mA at 1.5-A load current. This CMOS process also allows the LP3852 and LP3855 to operate under extremely low dropout conditions, typically 24 mV at 150-mA load current and 240 mV at 1.5-A load current.
The LP3852 has an ERROR pin; it goes low when the output voltage drops 10% below nominal value. The LP3855 has a SENSE pin to improves regulation at remote loads.
The LP3852 and LP3855 are available with fixed output voltages from 1.8 V to 5 V with a specified accuracy of ±1.5% at room temperature, and ±3% over all conditions (varying line, load, and temperature). Contact Texas Instruments Sales for specific voltage option needs.
