公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
具有使能功能的 800mA、低输入电压 (1.291V)、超低压降稳压器
Output options Fixed Output
Iout (Max) (A) 0.8
Vin (Max) (V) 5.5
Vin (Min) (V) 1.291
Vout (Max) (V) 1.8
Vout (Min) (V) 1.2
Fixed output options (V) 1.2, 1.5, 1.8
Noise (uVrms) 90
Iq (Typ) (mA) 4
Thermal resistance θJA (°C/W) 40
Rating Catalog
Load capacitance (Min) (μF) 4.7
Regulated outputs (#) 1
Features Enable
Accuracy (%) 2
PSRR @ 100 KHz (dB) 45
Dropout voltage (Vdo) (Typ) (mV) 75
Operating temperature range (C) -40 to 125
  • Ultra Low Dropout Voltage (75 mV @ 0.8A Typ)
  • Low Ground Pin Current
  • Load Regulation of 0.04%/A
  • 60 nA Typical Quiescent Current in Shutdown
  • 1.5% Output Accuracy (25°C)
  • TO-220, TO-263 and SOIC-8 Packages
  • Over Temperature/Over Current Protection
  • ?40°C to +125°C Junction Temperature Range
All trademarks are the property of their respective owners.
The LP3881 is a high current, fast response regulator which can maintain output voltage regulation with minimum input to output voltage drop. Fabricated on a CMOS process, the device operates from two input voltages: Vbias provides voltage to drive the gate of the N-MOS power transistor, while Vin is the input voltage which supplies power to the load. The use of an external bias rail allows the part to operate from ultra low Vin voltages. Unlike bipolar regulators, the CMOS architecture consumes extremely low quiescent current at any output load current. The use of an N-MOS power transistor results in wide bandwidth, yet minimum external capacitance is required to maintain loop stability.
The fast transient response of these devices makes them suitable for use in powering DSP, Microcontroller Core voltages and Switch Mode Power Supply post regulators. The parts are available in TO-220, TO-263 and SOIC-8 packages.
Dropout Voltage: 75 mV (typ) @ 0.8A load current.
Ground Pin Current: 3 mA (typ) at full load.
Shutdown Current: 60 nA (typ) when S/D pin is low.
Precision Output Voltage: 1.5% room temperature accuracy.
