Output options | Fixed Output |
Iout (Max) (A) | 1.5 |
Vin (Max) (V) | 38 |
Vin (Min) (V) | 7 |
Vout (Max) (V) | 24 |
Vout (Min) (V) | 5 |
Fixed output options (V) | 5, 8, 10, 12, 15, 24 |
Noise (uVrms) | 52 |
Iq (Typ) (mA) | 4.3 |
Thermal resistance θJA (°C/W) | 22 |
Rating | Catalog |
Load capacitance (Min) (μF) | 0.1 |
Regulated outputs (#) | 1 |
Accuracy (%) | 3.75 |
PSRR @ 100 KHz (dB) | 40 |
Dropout voltage (Vdo) (Typ) (mV) | 2000 |
Operating temperature range (C) | 0 to 125 |
- 3-Terminal Regulators
- Available in fixed 5-V/8-V/10-V/12-V/
15-V/24-V options - Output Current up to 1.5 A
- Internal Thermal-Overload Protection
- High Power-Dissipation Capability
- Internal Short-Circuit Current Limiting
- Output Transistor Safe-Area Compensation
- Output Capacitor Not Needed for Stability
This series of fixed-voltage integrated-circuit voltage regulators is designed for a wide range of applications. These applications include on-card regulation for elimination of noise and distribution problems associated with single-point regulation. Each of these regulators can deliver up to 1.5A of output current. The internal current-limiting and thermal-shutdown features of these regulators essentially make them immune to overload. In addition to use as fixed-voltage regulators, these devices can be used with external components to obtain adjustable output voltages and currents, and also can be used as the power-pass element in precision regulators.
