Output options | Fixed Output |
Iout (Max) (A) | 0.005 |
Vin (Max) (V) | 6 |
Vin (Min) (V) | 2.7 |
Vout (Max) (V) | 2.5 |
Vout (Min) (V) | 2.5 |
Fixed output options (V) | 2.5 |
Iq (Typ) (mA) | 0.014 |
Thermal resistance θJA (°C/W) | 255 |
Rating | Catalog |
Load capacitance (Min) (μF) | 2.2 |
Regulated outputs (#) | 1 |
Features | Enable |
Accuracy (%) | 2 |
PSRR @ 100 KHz (dB) | 40 |
Dropout voltage (Vdo) (Typ) (mV) | 200 |
Operating temperature range (C) | -40 to 125 |
- Miniature 5 Pin Package
- Logic Controlled Enable
- No Noise Bypass Capacitor Required
- Stable with Low ESR Ceramic Capacitors
- Fast Turn ON
- Short Circuit Protection
Key Specifications
- Input Voltage Range: 2.5V to 6.0V
- Output Voltages: 1.6V, 1.8V, and 2.5V
- Output Current: 5 mA
- Output Capacitors: 1μF Low ESR
- Virtually Zero IQ (Disabled): 1.0 μA
- Low IQ (Enabled): 14 μA
- PSRR: 10 dB
- Fast Start Up: 170 μs
Package
- 5 Bump Thin DSBGA Package
All trademarks are the property of their respective owners.
The LP3983 is a fixed voltage low current regulator.
The LP3983 is ideally suited to standby type applications in battery powered equipment, it allows the lifetime of the battery to be maximized. The device can be controlled via an Enable(disable) control and can thus be used by the system to further extend the battery lifetime by reducing the power consumption to virtually zero.
Performance is specified for a -40°C to 125°C temperature range.
For output voltages other than those stated and alternative package options, please contact your local NSC sales office.
