公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
具有低输出电压和使能功能的 150mA、16V、低压降稳压器
Output options Fixed Output
Iout (Max) (A) 0.15
Vin (Max) (V) 16
Vin (Min) (V) 2.2
Vout (Max) (V) 1.2
Vout (Min) (V) 1
Fixed output options (V) 1, 1.2
Noise (uVrms) 60
Iq (Typ) (mA) 0.065
Thermal resistance θJA (°C/W) 169
Rating Catalog
Load capacitance (Min) (μF) 2.2
Regulated outputs (#) 1
Features Enable
Accuracy (%) 1.5
PSRR @ 100 KHz (dB) 38
Dropout voltage (Vdo) (Typ) (mV) 1000
Operating temperature range (C) -40 to 125
  • Operating Input Supply Voltage: 2.2 V to 16 V
  • Output Current: 150 mA
  • Low ZOUT: 0.3 ? Typical (10 Hz to 1 MHz)
  • Stable with Low-ESR Output Capacitor
  • Low Ground Pin Current at All Loads
  • Output Voltage Accuracy 1% (A Grade)
  • High Peak Current Capability
  • Wide Supply Voltage Range (16 V Maximum)
  • Overtemperature and Overcurrent Protection
  • ?40°C to +125°C Junction Temperature Range
  • Requires Minimum External Components
The LP2983 is a 150-mA, fixed-output voltage regulator designed to provide tight voltage regulation in applications with output voltages ≤ 1.2 V.
Using an optimized vertically integrated PNP (VIP) process, the LP2983 delivers unequaled performance in all critical specifications:
  • Ground pin current: Typically 825 μA at a 150-mA load, and 75 μA at a 1-mA load.
  • Enhanced stability: The LP2983 is stable with output capacitor ESR down to zero, which allows the use of ceramic capacitors on the output.
  • Precision output: 1% tolerance output voltages available (A grade).
  • Smallest possible size: SOT-23 package uses absolute minimum board space.
For all available packages, see the orderable addendum at the end of the data sheet.
