1 / 6
公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  205粉丝
--- 产品详情 ---
耐辐射 QMLV、4.2V 至 40V 输入、1.5A 可调输出线性稳压器
Output options Adjustable Output
Iout (Max) (A) 1.5
Vin (Max) (V) 40
Vin (Min) (V) 4.2
Vout (Max) (V) 37
Vout (Min) (V) 1.25
Fixed output options (V) 0
Noise (uVrms) 75
Iq (Typ) (mA) 5
Thermal resistance θJA (°C/W) 39
Rating Space
Load capacitance (Min) (μF) 0
Regulated outputs (#) 1
Accuracy (%) 4
PSRR @ 100 KHz (dB) 40
Dropout voltage (Vdo) (Typ) (mV) 1200
Operating temperature range (C) -55 to 125, 25 to 25
Radiation, SEL (MeV.cm2/mg) Bipolar
Radiation, TID (Typ) (krad) 100
  • Radiation hardness assured (RHA) up to a total ionizing dose (TID) of 100 krad(Si)
    • High dose rate (HDR) option at 50-300 rad(Si)/s
    • Low dose rate (LDR) option at 10 mrad(Si)/s
  • Specified 0.5-A or 1.5-A output current options
  • Adjustable output down to 1.2 V
  • Current limit constant with temperature
  • Output is short-circuit protected
The LM117QML-SP 3-terminal positive voltage linear regulator is capable of supplying either 0.5 A or 1.5 A over a 1.2-V to 37-V output range. It is simple to use and requires only two external resistors to set the output voltage.
The regulator is "floating" and sees only the input-to-output differential voltage, thus enabling supplies of several hundred volts to be regulated as long as the maximum input-to-output differential is not exceeded.
The flight-proven LM117QML-SP offers full overload protection such as current limit, thermal overload protection, and safe area protection. It is exceptionally versatile and can also be used as an adjustable switching regulator, a programmable output regulator, a precision current regulator, and more.
For high voltage applications, the LM117HVQML-SP is a pin-to-pin drop-in replacement suitable for up to 60V. For the negative complement of the LM117QML-SP, see the LM137QML-SP.
