公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有 0°C 至 125°C 工作温度范围的 1A、15V 高精度线性稳压器
Output options Adjustable Output, Fixed Output
Iout (Max) (A) 1
Vin (Max) (V) 15
Vin (Min) (V) 2.5
Vout (Max) (V) 13.75
Vout (Min) (V) 1.5
Fixed output options (V) 1.8, 3.3
Noise (uVrms) 412.5
Iq (Typ) (mA) 5
Thermal resistance θJA (°C/W) 56
Rating Catalog
Load capacitance (Min) (μF) 10
Regulated outputs (#) 1
Accuracy (%) 3
PSRR @ 100 KHz (dB) 37
Dropout voltage (Vdo) (Typ) (mV) 1200
Operating temperature range (C) 0 to 125
  • Available in 1.8-V, 3.3-V, and Adjustable Versions
  • Space-Saving SOT-223 and TO-252 Packages
  • Current Limiting and Thermal Protection
  • Output Current: 1 A
  • Temperature Range: 0°C to 125°C
  • Line Regulation: 0.2% (Maximum)
  • Load Regulation: 0.4% (Maximum)
The LMS8117A device is a series of low-dropout voltage regulators with a dropout of 1.2 V at 1 A of load current. The device has the same pinout as the LM317.
The LMS8117A is available in an adjustable version, which can set the output voltage from 1.27 V to 13.8 V with only two external resistors. In addition, the device is also available in two fixed voltages, 1.8 V and 3.3 V.
The LMS8117A offers current limiting and thermal shutdown. The device circuit includes a Zener trimmed band-gap reference to assure output voltage accuracy to within ±1%.
The LMS8117A is available in SOT-223 and TO-252 D-PAK packages. A 10-μF (minimum) tantalum capacitor is required at the output to improve the transient response and stability.
