公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
具有使能功能的 300mA、双通道可调节超低压降稳压器
Output options Dual Output, Fixed Output
Iout (Max) (A) 0.3
Vin (Max) (V) 6
Vin (Min) (V) 2.5
Vout (Max) (V) 2.85
Vout (Min) (V) 2.5
Fixed output options (V) 1.8, 2.5, 2.8, 2.85, 3
Noise (uVrms) 40
Iq (Typ) (mA) 0.115
Thermal resistance θJA (°C/W) 220
Rating Catalog
Load capacitance (Min) (μF) 1
Regulated outputs (#) 2
Features Enable
Accuracy (%) 3
PSRR @ 100 KHz (dB) 35
Dropout voltage (Vdo) (Typ) (mV) 60
Operating temperature range (C) -40 to 125
  • Miniature 8-I/O DSBGA Package
  • Stable With 1μF Ceramic and High Quality Tantalum Output Capacitors
  • Fast Turn-on
  • Two Independent Regulators
  • Logic Controlled Enable
  • Over Current and Thermal Protection
The LP3986 is a 150 mA dual low dropout regulator designed for portable and wireless applications with demanding performance and board space requirements.
The LP3986 is stable with a small 1 μF ±30% ceramic output capacitor requiring smallest possible board space.
The LP3986's performance is optimized for battery powered systems to deliver ultra low noise, extremely low dropout voltage and low quiescent current independent of load current. Regulator ground current increases very slightly in dropout, further prolonging the battery life. Optional external bypass capacitor reduces the output noise further without slowing down the load transient response. Fast start-up time is achieved by utilizing a speed-up circuit that actively pre-charges the bypass capacitor. Power supply rejection is better than 60 dB at low frequencies and 55 dB at 10 kHz. High power supply rejection is maintained at low input voltage levels common to battery operated circuits.
The LP3986 is available in a DSBGA package. Performance is specified for a ?40°C to +125°C temperature range. For single LDO applications, please refer to the LP3985 datasheet.
