Output options | Adjustable Output |
Iout (Max) (A) | 0.1 |
Vin (Max) (V) | 35 |
Vin (Min) (V) | 3.75 |
Vout (Max) (V) | 32 |
Vout (Min) (V) | 1.2 |
Noise (uVrms) | 30 |
Iq (Typ) (mA) | 1.5 |
Thermal resistance θJA (°C/W) | 52 |
Rating | Catalog |
Load capacitance (Min) (μF) | 0 |
Regulated outputs (#) | 1 |
Accuracy (%) | 4 |
PSRR @ 100 KHz (dB) | 38 |
Dropout voltage (Vdo) (Typ) (mV) | 2000 |
Operating temperature range (C) | -40 to 125, 0 to 125 |
- Output Voltage Range Adjustable 1.25V to 32V
When Used With External Resistor Divider - Output Current Capability of 100 mA
- Input Regulation Typically 0.01% Per Input-Voltage
Change - Output Regulation Typically 0.5%
- Ripple Rejection Typically 80 dB
- For Higher Output Current Requirements,
SeeLM317M(500 mA) and LM317(1.5 A)
- Electronic Points of Sale
- Medical, Health, and Fitness Applications
- Printers
- Appliances and White Goods
- TV Set-Top Boxes
All other trademarks are the property of their respective owners
The LM317L device is an adjustable, 3-terminal, positive-voltage regulator capable of supplying 100mA over an output-voltage range of 1.25V to 32V. It is exceptionally easy to use and requires only two external resistors to set the output voltage.
