Output options | Fixed Output |
Iout (Max) (A) | 0.15 |
Vin (Max) (V) | 16 |
Vin (Min) (V) | 2.2 |
Vout (Max) (V) | 2 |
Vout (Min) (V) | 1.5 |
Fixed output options (V) | 1.5, 1.8, 2 |
Noise (uVrms) | 30 |
Iq (Typ) (mA) | 2 |
Thermal resistance θJA (°C/W) | 176 |
Rating | Catalog |
Load capacitance (Min) (μF) | 2.2 |
Regulated outputs (#) | 1 |
Features | Enable |
Accuracy (%) | 2 |
PSRR @ 100 KHz (dB) | 30 |
Dropout voltage (Vdo) (Typ) (mV) | 600 |
Operating temperature range (C) | -40 to 125 |
- Wide Supply Voltage Range: 2.2 V to 16 V
- Ensured 150-mA Output Current
- Requires Minimum External Components
- Stable With Low-ESR Output Capacitor
- < 1-μA Quiescent Current When Shut Down
- Low Ground Pin Current at all Loads
- Output Voltage Accuracy 1% (A Grade)
- High Peak Current Capability
- Low ZOUT: 0.3-? Typical (10 Hz to 1 MHz)
- Overtemperature/Overcurrent Protection
- ?40°C to +125°C Junction Temperature Range
The LP2985LV-N is a 150-mA, fixed-output voltage regulator designed to provide high performance and low noise in applications requiring output voltages ≤ 2 V.
Using an optimized vertically integrated PNP (VIP) process, the LP2985LV-N delivers unequaled performance in all specifications critical to battery-powered designs: Ground Pin Current: Typically 825 μA at 150-mA load, and 75 μA at 1-mA load. Enhanced Stability: The LP2985LV-N is stable with output capacitor equivalent series resistance (ESR) as low as 5 m?, which allows the use of ceramic capacitors on the output.Sleep Mode: Less than 1-μA quiescent current when ON/OFF pin is pulled low.Precision Output: 1% tolerance output voltages available (A grade). Low Noise: By adding a 10-nF bypass capacitor, output noise can be reduced to 30 μV (typical).
For all available packages, see the orderable addendum at the end of the data sheet.
