Output options | Fixed Output |
Iout (Max) (A) | 0.1 |
Vin (Max) (V) | 16 |
Vin (Min) (V) | 3.7 |
Vout (Max) (V) | 5 |
Vout (Min) (V) | 3 |
Fixed output options (V) | 3, 3.2, 3.3, 3.8, 5 |
Noise (uVrms) | 190 |
Iq (Typ) (mA) | 0.09 |
Thermal resistance θJA (°C/W) | 180 |
Rating | Catalog |
Load capacitance (Min) (μF) | 4.7 |
Regulated outputs (#) | 1 |
Features | Enable |
Accuracy (%) | 2 |
Dropout voltage (Vdo) (Typ) (mV) | 170 |
Operating temperature range (C) | -40 to 125 |
- 100-mA Low-Dropout Regulator
- Fixed Output Voltage Options: 5 V, 3.8 V, 3.3 V, 3.2 V, and 3 V
- Dropout Typically 170 mV at 100-mA
- Thermal Protection
- Less Than 1 uA Quiescent Current in Shutdown
- \x9640°C to 125°C Operating Junction Temperature Range
- 5-Pin SOT-23 (DBV) Package
- ESD Protection Verified to 1.5 KV Human Body Model (HBM) per MIL-STD-883C
The TPS761xx is a 100 mA, low dropout (LDO) voltage regulator designed specifically for battery-powered applications. A proprietary BiCMOS fabrication process allows the TPS761xx to provide outstanding performance in all specifications critical to battery-powered operation.
The TPS761xx is available in a space-saving SOT-23 (DBV) package and operates over a junction temperature range of \x9640°C to 125°C.
