1 / 3
公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  205粉丝
--- 产品详情 ---
具有电源正常指示和使能功能的 500mA、16V、低压降稳压器
Output options Fixed Output
Iout (Max) (A) 0.5
Vin (Max) (V) 16
Vin (Min) (V) 2.1
Vout (Max) (V) 5
Vout (Min) (V) 2.5
Fixed output options (V) 2.5, 2.8, 3, 3.3, 3.8, 5
Noise (uVrms) 18
Iq (Typ) (mA) 0.11
Thermal resistance θJA (°C/W) 35
Rating Catalog
Load capacitance (Min) (μF) 4.7
Regulated outputs (#) 1
Features Enable, Power good
Accuracy (%) 2
PSRR @ 100 KHz (dB) 32
Dropout voltage (Vdo) (Typ) (mV) 310
Operating temperature range (C) -40 to 125
  • 2.1-V to 16-V Input Voltage Range
  • 2.5-V to 5-V Fixed Output Voltage Options
  • Ultra-Low Dropout Voltage
  • 500-mA Continuous Output Current
  • Very Low Output Noise With External Capacitor
  • < 0.8-μA Quiescent Current When Shutdown
  • Low Ground Pin Current at All Loads
  • 0.75% Output Voltage Accuracy (A Grade)
  • High Peak Current Capability (800-mA typical)
  • Overtemperature and Overcurrent Protection
  • ?40°C to 125°C Junction Temperature Range
The LP2989 is a fixed-output 500-mA precision LDO regulator designed for use with ceramic output capacitors.
Output noise can be reduced to 18 μV (typical) by connecting an external 10-nF capacitor to the bypass pin.
Using an optimized Vertically Integrated PNP (VIP) process, the LP2989 delivers superior performance:
  • Dropout Voltage: Typically 310 mV at 500-mA load, and 1 mV at 100-μA load.
  • Ground Pin Current: Typically 3 mA at 500-mA load, and 110 μA at 100-μA load.
  • Sleep Mode: The LP2989 draws less than 0.8-μA quiescent current when SHUTDOWN pin is pulled low.
  • Error Flag: The built-in error flag goes low when the output drops approximately 5% below nominal.
  • Precision Output: Output voltage accuracy is 0.75% (A grade) and 1.25% (standard grade) at room temperature.
For output voltages < 2 V, see LP2989LV (SNVS086) data sheet.
