公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
具有使能功能的 150mA、16V、低压降稳压器
Output options Fixed Output
Iout (Max) (A) 0.15
Vin (Max) (V) 16
Vin (Min) (V) 2.2
Vout (Max) (V) 6.1
Vout (Min) (V) 1.8
Fixed output options (V) 2.5, 2.6, 2.7, 2.8, 2.9, 3, 3.1, 3.2, 3.3, 3.5, 3.6, 3.8, 4, 4.5, 5, 6.1
Noise (uVrms) 30
Iq (Typ) (mA) 0.065
Thermal resistance θJA (°C/W) 169
Rating Catalog
Load capacitance (Min) (μF) 2.2
Regulated outputs (#) 1
Features Enable
Accuracy (%) 2
PSRR @ 100 KHz (dB) 30
Dropout voltage (Vdo) (Typ) (mV) 280
Operating temperature range (C) -40 to 125
  • Input Voltage Range: 2.5 V to 16 V
  • Ultra Low-Dropout Voltage
  • Ensured 150 mA Output Current
  • Requires Minimum External Components
  • Stable With Low-ESR Output Capacitor
  • < 1 μA Quiescent Current When Shut Down
  • Low Ground Pin Current at All Loads
  • Output Voltage Accuracy 1% (A Grade)
  • High Peak Current Capability
  • Low ZOUT: 0.3 ? Typical (10 Hz to 1 MHz)
  • Overtemperature and Overcurrent Protection
  • ?40°C to 125°C Junction Temperature Range
  • Custom Voltages Available
The LP2985-N low noise linear (LDO) regulator delivers up to 150-mA output current and only requires 300-mV dropout voltage of input to output. Using an optimized vertically integrated PNP (VIP) process, the LP2985-N delivers unequaled performance for all battery-powered designs. The LP2985-N device provides 1% tolerance precision output voltage with only 75-μA quiescent current at 1-mA load and 850 μA at 150-mA load. By adding a 10-nF bypass capacitor, the output noise can be reduced to 30 μVRMS in a 30-kHz bandwidth.
The LP2985-N is designed to work with a ceramic output capacitor with equivalent series resistance (ESR) as low as 5 m?. The device is available with fixed output voltage from 2.5 V to 6.1 V. Contact Texas Instrument Sales for specific voltage option needs.
For all available packages, see the orderable addendum at the end of the data sheet.
