Output options | Fixed Output |
Iout (Max) (A) | 0.1 |
Vin (Max) (V) | 16 |
Vin (Min) (V) | 2.7 |
Vout (Max) (V) | 5 |
Vout (Min) (V) | 2.5 |
Fixed output options (V) | 2.5, 3, 3.3, 3.6, 5 |
Noise (uVrms) | 160 |
Iq (Typ) (mA) | 0.065 |
Thermal resistance θJA (°C/W) | 176 |
Rating | Catalog |
Load capacitance (Min) (μF) | 2.2 |
Regulated outputs (#) | 1 |
Features | Enable |
Accuracy (%) | 2 |
PSRR @ 100 KHz (dB) | 41 |
Dropout voltage (Vdo) (Typ) (mV) | 200 |
Operating temperature range (C) | -40 to 125 |
- Operating Input Voltage Range: 2.1 V to 16 V
- Ultralow-Dropout Voltage
- Output Voltage Accuracy 0.75% (A Grade)
- Specified 100-mA Output Current
- < 1-μA Quiescent Current when Shutdown
- Low Ground Pin Current at All Load Currents
- High Peak Current Capability (300 mA Typical)
- Wide Supply Voltage Range (16 V Maximum)
- Fast Dynamic Response to Line and Load
- Low ZOUT Over Wide Frequency Range
- Overtemperature and Overcurrent Protection
- ?40°C to 125°C Junction Temperature Range
The LP2981-N is a 100-mA, fixed-output voltage regulator designed specifically to meet the requirements of battery-powered applications.
Using an optimized Vertically Integrated PNP (VIP) process, the LP2981-N delivers unequaled performance in all specifications critical to battery-powered designs:
Dropout Voltage: Typically 200 mV at 100-mA load, and 7mV at 1-mA load.
Ground Pin Current: Typically 600 μA at 100-mA load, and 80 μA at 1-mA load.
Sleep Mode: Less than 1-μA quiescent current when ON/OFF pin is pulled low.
Precision Output: 0.75% tolerance output voltages available (A grade).
Assorted voltage options, from 2.5 V to 5 V, are available as standard products.
For all available packages, see the orderable addendum at the end of the data sheet.
