Output options | Fixed Output |
Iout (Max) (A) | 1 |
Vin (Max) (V) | 5.5 |
Vin (Min) (V) | 4.5 |
Vout (Max) (V) | 3.3 |
Vout (Min) (V) | 3.3 |
Fixed output options (V) | 3.3 |
Noise (uVrms) | 150 |
Iq (Typ) (mA) | 0.11 |
Thermal resistance θJA (°C/W) | 23 |
Rating | Catalog |
Load capacitance (Min) (μF) | 33 |
Regulated outputs (#) | 1 |
Accuracy (%) | 2.5 |
PSRR @ 100 KHz (dB) | 32 |
Dropout voltage (Vdo) (Typ) (mV) | 310 |
Operating temperature range (C) | -40 to 125 |
- Input Voltage Range: 4.5 V to 5.5 V
- Output Voltage Specified over Temperature
- Excellent Load Regulation
- Specified 1-A Output Current
- Requires only One External Component
- Built-in Protection against Excess Temperature
- Short-Circuit Protected
The LM3940 is a 1-A low-dropout regulator designed to provide 3.3 V from a 5-V supply.
The LM3940 is ideally suited for systems which contain both 5-V and 3.3-V logic, with prime power provided from a 5-V bus.
Because the LM3940 is a true low dropout regulator, it can hold its 3.3-V output in regulation with input voltages as low as 4.5 V.
The TO-220 package of the LM3940 means that in most applications the full 1 A of load current can be delivered without using an additional heatsink.
The surface mount DDPAK/TO-263 package uses minimum board space, and gives excellent power dissipation capability when soldered to a copper plane on the PC board.
