公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
具有使能功能的 50mA、16V、低压降稳压器
Output options Fixed Output
Iout (Max) (A) 0.05
Vin (Max) (V) 16
Vin (Min) (V) 2.1
Vout (Max) (V) 5
Vout (Min) (V) 2.5
Fixed output options (V) 2.5, 3, 3.3, 3.8, 4.7, 5
Noise (uVrms) 160
Iq (Typ) (mA) 0.065
Thermal resistance θJA (°C/W) 175
Rating Catalog
Load capacitance (Min) (μF) 2.2
Regulated outputs (#) 1
Features Enable
Accuracy (%) 3
PSRR @ 100 KHz (dB) 45
Dropout voltage (Vdo) (Typ) (mV) 120
Operating temperature range (C) -40 to 125
  • 2.1-V to 16-V Input Voltage Range
  • 5-V, 4.7-V, 3.3-V, 3-V, and 2.5-V Output Versions
  • Ultra-Low-Dropout Voltage
  • Output Voltage Accuracy 0.5% (A Grade)
  • Ensured 50-mA Output Current
  • Requires Only 1-μF External Capacitance
  • < 1-μA Quiescent Current When Shutdown
  • Low Ground Pin Current at All Load Currents
  • High Peak Current Capability (150 mA Typical)
  • Wide Supply Voltage Range (16 V Maximum)
  • Fast Dynamic Response to Line and Load
  • Low ZOUT Over Wide Frequency Range
  • Overtemperature and Overcurrent Protection
  • ?40°C to 125°C Junction Temperature Range
The LP2980-N is a 50-mA, fixed-output voltage regulator designed specifically to meet the requirements of battery-powered applications.
Using an optimized VIP (Vertically Integrated PNP) process, the LP2980-N delivers unequaled performance in all specifications critical to battery-powered designs:
Dropout voltage: Typically 120 mV at 50-mA load, and 7mV at 1-mA load.
Ground pin current: Typically 375 μA at 50-mA load, and 80 μA at 1-mA load.
Sleep mode: Less than 1-μA quiescent current when ON/OFF pin is pulled to less than 0.18 V.
Minimum part count: Requires only a 1-μF capacitor on the regulator output.
Precision output: Initial output voltage tolerance of ±0.5% (A grade).
5-V, 4.7-V, 3.3-V, 3-V, and 2.5-V versions available as standard products.
For all available packages, see the orderable addendum at the end of the data sheet.
