公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
500mA、26V、高 PSRR、低压降稳压器
Output options Fixed Output
Iout (Max) (A) 0.5
Vin (Max) (V) 26
Vin (Min) (V) 6
Vout (Max) (V) 15
Vout (Min) (V) 5
Fixed output options (V) 5, 8, 10, 12, 15
Noise (uVrms) 150
Iq (Typ) (mA) 2
Thermal resistance θJA (°C/W) 42
Rating Catalog
Load capacitance (Min) (μF) 10
Regulated outputs (#) 1
Accuracy (%) 5
PSRR @ 100 KHz (dB) 57
Dropout voltage (Vdo) (Typ) (mV) 500
Operating temperature range (C) -40 to 125, -40 to 85
  • Fully Specified for Operation Over ?40°C
    to 125°C
  • Output Current in Excess of 500 mA
  • Output Trimmed for 5% Tolerance Under all Operating
    Conditions
  • Typical Dropout Voltage of 0.5 V at Full Rated Load
    Current
  • Wide Output Capacitor ESR Range, up to 3 Ω
  • Internal Short Circuit and Thermal Overload Protection
  • Reverse Battery Protection
  • 60-V Input Transient Protection
  • Mirror Image Insertion Protection
The LM2937 is a positive voltage regulator capable of supplying up to 500 mA of load current. The use of a PNP power transistor provides a low dropout voltage characteristic. With a load current of 500 mA the minimum input to output voltage differential required for the output to remain in regulation is typically 0.5 V (1-V ensured maximum over the full operating temperature range). Special circuitry has been incorporated to minimize the quiescent current to typically only 10 mA with a full 500-mA load current when the input to output voltage differential is greater than 3 V.
The LM2937 requires an output bypass capacitor for stability. As with most low dropout regulators, the ESR of this capacitor remains a critical design parameter, but the LM2937 includes special compensation circuitry that relaxes ESR requirements. The device is stable for all ESR below 3 Ω. This allows the use of low ESR chip capacitors.
Ideally suited for automotive applications, the LM2937 will protect itself and any load circuitry from reverse battery connections, two-battery jumps, and up to 60-V/?50-V load dump transients. Familiar regulator features such as short circuit and thermal shutdown protection are also built in.
