公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
负低压降可调节稳压器
Output options Adjustable Output, Negative Output
Iout (Max) (A) 1
Vin (Max) (V) 0.3
Vin (Min) (V) -26
Vout (Max) (V) -3
Vout (Min) (V) -24
Fixed output options (V) 0
Noise (uVrms) 200
Iq (Typ) (mA) 0.7
Thermal resistance θJA (°C/W) 28
Rating Military
Load capacitance (Min) (μF) 1
Regulated outputs (#) 1
Features Enable
Accuracy (%) 5
PSRR @ 100 KHz (dB) 22
Dropout voltage (Vdo) (Typ) (mV) 600
Operating temperature range (C) -55 to 125, -40 to 85
  • Output voltage adjustable from ?2V to ?25V
  • Output current in excess of 1A
  • Dropout voltage typically 0.6V at 1A load
  • Low quiescent current
  • Internal short circuit current limit
  • Internal thermal shutdown with hysteresis
  • TTL, CMOS compatible ^ON/OFF switch
  • Functional complement to the LM2941 series
  • The LM2991 is a low dropout adjustable negative regulator with a output voltage range between ?2V to ?25V. The LM2991 provides up to 1A of load current and features a ^On /Off pin for remote shutdown capability.
    The LM2991 uses new circuit design techniques to provide a low dropout voltage, low quiescent current and low temperature coefficient precision reference. The dropout voltage at 1A load current is typically 0.6V and a guaranteed worst-case maximum of 1V over the entire operating temperature range. The quiescent current is typically 1 mA with a 1A load current and an input-output voltage differential greater than 3V. A unique circuit design of the internal bias supply limits the quiescent current to only 9 mA (typical) when the regulator is in the dropout mode (VO ? VI 3V).
    The LM2991 is short-circuit proof, and thermal shutdown includes hysteresis to enhance the reliability of the device when inadvertently overloaded for extended periods.
