Output options | Fixed Output |
Iout (Max) (A) | 0.05 |
Vin (Max) (V) | 40 |
Vin (Min) (V) | 4 |
Vout (Max) (V) | 5 |
Vout (Min) (V) | 3.3 |
Fixed output options (V) | 3.3, 5 |
Iq (Typ) (mA) | 0.02 |
Thermal resistance θJA (°C/W) | 50 |
Rating | Catalog |
Load capacitance (Min) (μF) | 22 |
Regulated outputs (#) | 1 |
Accuracy (%) | 3 |
Dropout voltage (Vdo) (Typ) (mV) | 200 |
Operating temperature range (C) | -40 to 125 |
- Ultra low Ground Pin Current (IGND ≤ 25μA for IOUT =0.1mA)
- Fixed 5V, 3.3V, 50mA Output
- Output Tolerance ±5% Over Line, Load, and Temperature
- Dropout Voltage Typically 200mV @ IOUT = 50mA
- ?45V Reverse Transient Protection
- Internal Short Circuit Current Limit
- Internal Thermal Shutdown Protection
- 40V Operating Voltage Limit
All trademarks are the property of their respective owners.
The LM9036 ultra-low quiescent current regulator features low dropout voltage and low current in the standby mode. With less than 25μA Ground Pin current at a 0.1mA load, the LM9036 is ideally suited for automotive and other battery operated systems. The LM9036 retains all of the features that are common to low dropout regulators including a low dropout PNP pass device, short circuit protection, reverse battery protection, and thermal shutdown. The LM9036 has a 40V maximum operating voltage limit, a ?40°C to +125°C operating temperature range, and ±5% output voltage tolerance over the entire output current, input voltage, and temperature range.
