公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
军用级 1.5A 可调节输出线性稳压器/LDO
Output options Adjustable Output
Iout (Max) (A) 1.5
Vin (Max) (V) 40
Vin (Min) (V) 4.2
Vout (Max) (V) 37
Vout (Min) (V) 1.25
Fixed output options (V) 0
Noise (uVrms) 75
Iq (Typ) (mA) 5
Thermal resistance θJA (°C/W) 39
Rating Military
Load capacitance (Min) (μF) 0
Regulated outputs (#) 1
Accuracy (%) 4
PSRR @ 100 KHz (dB) 40
Dropout voltage (Vdo) (Typ) (mV) 1200
Operating temperature range (C) -55 to 125
  • Available with Radiation Ensured
    • High Dose Rate 100 krad(Si)
    • ELDRS Free 100 krad(Si)
  • Specified max. 0.3% Load Regulation (LM117)
  • Specified 0.5A or 1.5A Output Current
  • Adjustable Output Down to 1.2V
  • Current Limit Constant with Temperature
  • 80 dB Ripple Rejection
  • Output is Short-Circuit Protected
All trademarks are the property of their respective owners.
The LM117 series of adjustable 3-terminal positive voltage regulators is capable of supplying either 0.5A or 1.5A over a 1.2V to 37V output range. They are exceptionally easy to use and require only two external resistors to set the output voltage. Further, both line and load regulation are better than standard fixed regulators.
In addition to higher performance than fixed regulators, the LM117 series offers full overload protection available only in IC's. Included on the chip are current limit, thermal overload protection and safe area protection. All overload protection circuitry remains fully functional even if the adjustment terminal is disconnected.
Normally, no capacitors are needed unless the device is situated more than 6 inches from the input filter capacitors in which case an input bypass is needed. An optional output capacitor can be added to improve transient response. The adjustment terminal can be bypassed to achieve very high ripple rejection ratios which are difficult to achieve with standard 3-terminal regulators.
Besides replacing fixed regulators, the LM117 is useful in a wide variety of other applications. Since the regulator is "floating" and sees only the input-to-output differential voltage, supplies of several hundred volts can be regulated as long as the maximum input to output differential is not exceeded, i.e., avoid short-circuiting the output.
Also, it makes an especially simple adjustable switching regulator, a programmable output regulator, or by connecting a fixed resistor between the adjustment pin and output, the LM117 can be used as a precision current regulator. Supplies with electronic shutdown can be achieved by clamping the adjustment terminal to ground which programs the output to 1.2V where most loads draw little current.
For the negative complement, see LM137 series data sheet.
