公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
军用级 1A 固定输出线性稳压器/LDO
Output options Fixed Output
Iout (Max) (A) 1
Vin (Max) (V) 35
Vin (Min) (V) 17.6
Vout (Max) (V) 15
Vout (Min) (V) 5
Fixed output options (V) 5, 12, 15
Noise (uVrms) 40
Iq (Typ) (mA) 7
Thermal resistance θJA (°C/W) 232
Rating Military
Load capacitance (Min) (μF) 0
Regulated outputs (#) 1
Accuracy (%) 2
PSRR @ 100 KHz (dB) 40
Dropout voltage (Vdo) (Typ) (mV) 2500
Operating temperature range (C) -55 to 125
  • Complete Specifications at 1.0A and 0.5A Loads
  • No External Components
  • Internal Thermal Overload Protection
  • Internal Short Circuit Current-Limiting
  • Output Transistor Safe-Area Compensation
All trademarks are the property of their respective owners.
The monolithic 3-terminal positive voltage regulators employ internal current-limiting, thermal shutdown and safe-area compensation, making them essentially indestructible. If adequate heat sinking is provided, they can deliver over 0.5A output current. They are intended as fixed voltage regulators in a wide range of applications including local (on-card) regulation for elimination of noise and distribution problems associated with single-point regulation. In addition to use as fixed voltage regulators, these devices can be used with external components to obtain adjustable output voltages and currents.
Considerable effort was expended to make the entire series of regulators easy to use and minimize the number of external components. It is not necessary to bypass the output, although this does improve transient response. Input bypassing is needed only if the regulator is located far from the filter capacitor of the power supply.
