Output options | Fixed Output |
Iout (Max) (A) | 0.5 |
Vin (Max) (V) | 35 |
Vin (Min) (V) | 7.2 |
Vout (Max) (V) | 15 |
Vout (Min) (V) | 5 |
Fixed output options (V) | 5 |
Noise (uVrms) | 40 |
Iq (Typ) (mA) | 4 |
Thermal resistance θJA (°C/W) | 38 |
Rating | Catalog |
Load capacitance (Min) (μF) | 0.1 |
Regulated outputs (#) | 1 |
Accuracy (%) | 3 |
PSRR @ 100 KHz (dB) | 40 |
Dropout voltage (Vdo) (Typ) (mV) | 1800 |
Operating temperature range (C) | -40 to 125 |
- For a lower cost alternative, see the UA78M
- Output current in excess of 0.5 A
- No external components
- Internal thermal overload protection
- Internal short circuit current-limiting
- Output transistor safe-area compensation
- Available in 3-pin TO-220, TO-252, and TO packages
- Output voltages of 5 V and 15 V
The LM341 and LM78M05 three-pin positive voltage regulators employ built-in current limiting, thermal shutdown, and safe-operating area protection, which makes them virtually immune to damage from output overloads.
With adequate heat sinking, they can deliver in excess of 0.5-A output current. Typical applications would include local (on-card) regulators which can eliminate the noise and degraded performance associated with single-point regulation.
