公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
150mA 可调输出线性稳压器/LDO
Output options Adjustable Output
Iout (Max) (A) 0.15
Vin (Max) (V) 40
Vin (Min) (V) 9.5
Vout (Max) (V) 37
Vout (Min) (V) 2
Noise (uVrms) 86
Iq (Typ) (mA) 1.7
Thermal resistance θJA (°C/W) 66
Rating Military
Load capacitance (Min) (μF) 0
Regulated outputs (#) 1
Accuracy (%) 3
Dropout voltage (Vdo) (Typ) (mV) 3000
Operating temperature range (C) -55 to 150
  • 150 mA Output Current Without External Pass Transistor
  • Output Currents in Excess of 10A Possible by Adding External Transistors
  • Input Voltage 40V Max
  • Output Voltage Adjustable from 2V to 37V
  • Can be Used as Either a Linear or a Switching Regulator
All trademarks are the property of their respective owners.
The LM723/LM723C is a voltage regulator designed primarily for series regulator applications. By itself, it will supply output currents up to 150 mA; but external transistors can be added to provide any desired load current. The circuit features extremely low standby current drain, and provision is made for either linear or foldback current limiting.
The LM723/LM723C is also useful in a wide range of other applications such as a shunt regulator, a current regulator or a temperature controller.
The LM723C is identical to the LM723 except that the LM723C has its performance ensured over a 0°C to +70°C temperature range, instead of ?55°C to +125°C.
