公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  196粉丝
--- 产品详情 ---
150mA、26V、低噪声、低压降稳压器
Output options Fixed Output
Iout (Max) (A) 0.15
Vin (Max) (V) 26
Vin (Min) (V) 6
Vout (Max) (V) 5
Vout (Min) (V) 5
Fixed output options (V) 5
Noise (uVrms) 50
Iq (Typ) (mA) 3.5
Thermal resistance θJA (°C/W) 50
Rating Catalog
Load capacitance (Min) (μF) 10
Regulated outputs (#) 1
Accuracy (%) 1.4
PSRR @ 100 KHz (dB) 38
Dropout voltage (Vdo) (Typ) (mV) 320
Operating temperature range (C) 0 to 70
  • Input-output Differential Less than 0.6V
  • Output Current of 150 mA
  • Reverse Battery Protection
  • Line Transient Protection
  • Internal Short Circuit Current Limit
  • Internal Thermal Overload Protection
  • Mirror-image Insertion Protection
  • P+ Product Enhancement Tested
All trademarks are the property of their respective owners.
The LM330-N 5V 3-terminal positive voltage regulator features an ability to source 150 mA of output current with an input-output differential of 0.6V or less. Familiar regulator features such as current limit and thermal overload protection are also provided.
The low dropout voltage makes the LM330-N useful for certain battery applications since this feature allows a longer battery discharge before the output falls out of regulation. For example, a battery supplying the regulator input voltage may discharge to 5.6V and still properly regulate the system and load voltage. Supporting this feature, the LM330-N protects both itself and regulated systems from negative voltage inputs resulting from reverse installations of batteries.
Other protection features include line transient protection up to 26V, when the output actually shuts down to avoid damaging internal and external circuits. Also, the LM330-N regulator cannot be harmed by a temporary mirror-image insertion.
