公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
具有电源正常指示和使能功能的 100mA、30V、可调节低压降稳压器
Output options Adjustable Output
Iout (Max) (A) 0.1
Vin (Max) (V) 30
Vin (Min) (V) 2.43
Vout (Max) (V) 29
Vout (Min) (V) 1.24
Noise (uVrms) 100
Iq (Typ) (mA) 15
Thermal resistance θJA (°C/W) 160
Rating Catalog
Load capacitance (Min) (μF) 1
Regulated outputs (#) 1
Features Enable, Power good
Accuracy (%) 3
PSRR @ 100 KHz (dB) 13
Dropout voltage (Vdo) (Typ) (mV) 430
Operating temperature range (C) -40 to 125
  • High Accuracy 5V Specified 100mA Output
  • Extremely Low Quiescent Current
  • Low Dropout Voltage
  • Extremely Tight Load and Line Regulation
  • Very Low Temperature Coefficient
  • Use as Regulator or Reference
  • Needs Only 1μF for Stability
  • Current and Thermal Limiting
LP4951C Versions Only
  • Error Flag Warns of Output Dropout
  • Logic-controlled Electronic Shutdown
  • Output Pogrammable From 1.24 to 29V
All trademarks are the property of their respective owners.
The LP4950C and LP4951C are micropower voltage regulators with very low quiescent current (75μA typ.) and very low dropout voltage (typ. 40mV at light loads and 380mV at 100mA). They are ideally suited for use in battery-powered systems. Furthermore, the quiescent current of the LP4950C/LP4951C increases only slightly in dropout, prolonging battery life.
The LP4950C in the popular 3-pin TO-92 package is pin compatible with older 5V regulators. The 8-lead LP4951C is available in a plastic surface mount package and offers additional system functions.
One such feature is an error flag output which warns of a low output voltage, often due to falling batteries on the input. It may be used for a power-on reset. A second feature is the logic-compatible shutdown input which enables the regulator to be switched on and off. Also, the part may be pin-strapped for a 5V output or programmed from 1.24V to 29V with an external pair of resistors.
Careful design of the LP4950C/LP4951C has minimized all contributions to the error budget. This includes a tight initial tolerance (.5% typ.), extremely good load and line regulation (.05% typ.) and a very low output voltage temperature coefficient, making the part useful as a low-power voltage reference.
