公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
集成电源管理 IC (PMIC) 音频编解码器硅片
Regulated outputs (#) 14
Vin (Min) (V) 2.7
Vin (Max) (V) 5.5
Iout (Max) (A) 1.4
Rating Catalog
LDO 11
Iq (Typ) (mA) 0.03
Features Comm Control, Power Sequencing
Processor name OMAP
Processor supplier Texas Instruments
Switching frequency (Typ) (kHz) 3200
Configurability Factory programmable
  • Power:
    • Three Efficient Step-down Converters
    • 10 External Linear LDOs for Clocks and Peripherals
    • SmartReflex Dynamic Voltage Management
  • Audio:
    • Voice Codec
    • 15-Bit Linear Codec (8 and 16 kHz)
    • Differential Input Main and Submicrophones
    • Differential Headset Microphone Input
    • Auxiliary/FM Input (Mono or Stereo)
    • Differential 32-? Speaker and 16-? Headset Drivers (External Predrivers for Class D)
    • 8-? Stereo Class-D Drivers
    • Pulse Code Modulation (PCM) and TDM Interfaces
    • Interface
    • Automatic Level Control (ALC)
    • Digital and Analog Mixing
    • 16-Bit Linear Audio Stereo DAC (96, 48, 44.1, and 32 kHz, and Derivatives)
    • 16-Bit Linear Audio Stereo ADC (48, 44.1, and 32 kHz, and Derivatives)
    • Carkit
  • Charger:
    • Li-ion, Li-on Polymer, and Cobalt-Nickel-Manganese Charger
    • Backup Battery Charger
  • USB:
    • USB 2.0 OTG-Compliant HS Transceivers
    • 12-Bit ULPI
    • USB Power Supply (5-V CP for VBUS)
    • CEA-2011: OTG Transceiver Interface Specification
    • CEA-936A: Mini-USB Analog Carkit Interface Specification
  • Additional Features:
    • LED Driver Circuit for Two External LEDs
    • RTC and Retention Modules
    • HS Inter-Integrated Circuit (I2C) Serial Control
    • Thermal Shutdown and Hot-Die Detection
    • External Vibrator (Vibrator) Control
    • 19 GPIO Devices
    • 0.8-mm Pitch, 169-Pin, 12-mm × 12-mm Package
The TPS65951 device is a power-management IC for mobile cellular handsets powered by a Li-ion, Li-ion polymer, or cobalt-nickel-manganese cell battery. The device can be connected to an application processor and/or a modem. This optimized power-management IC is designed to support the specific power requirements of the OMAP processor devices. The TPS65951 contains several buck converters, low dropout (LDO) regulators, a battery charger interface, and a host of other features and functions. The audio portion of the TPS65951 is an entire audio module with audio codecs, digital filters, input preamplifiers and amplifiers, and class-D output amplifiers.
This TPS65951 Data Manual presents the electrical and mechanical specifications for the TPS65951 device.
