公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
具有 WLED 驱动器和电流并联监控器的锂离子电池充电器
Regulated outputs (#) 2
Vin (Min) (V) 2.5
Vin (Max) (V) 6
Iout (Max) (A) 0.2
Rating Catalog
LDO 1
Features Comm Control
Processor name Vizplex
Processor supplier E Ink
Switching frequency (Typ) (kHz) 600
Configurability Software configurable
  • Battery Switching Charger, WLED Driver, and
    Current Shunt Monitor in a Single Package
  • Battery Charger
    • Charges Faster Than Linear Chargers
    • High-Accuracy Voltage and Current Regulation
      • Input Current Regulation Accuracy: ±5%
        (100 mA, 500 mA)
      • Charge Voltage Regulation Accuracy:
        ±0.5% (25°C)
        ±1% (0 - 125°C)
      • Charge Current Regulation Accuracy: ±5%
    • Bad Adaptor Detection and Rejection
    • Safety Limit Register for Maximum Charge
      Voltage and Current Limiting
    • High-Efficiency Mini-USB/AC Battery Charger
      for Single-Cell Li-Ion and Li-Polymer Battery
      Packs
    • Built-In Input Current Sensing and Limiting
    • Integrated Power FETs for Up to 1.25-A
      Charge Rate
    • Programmable Charge Parameters through I2C
      Interface (Up to 400 Kbps):
      • Input Current
      • Fast-Charge/Termination Current
      • Charge Voltage (3.5 V – 4.44 V)
      • Safety Timer
      • Termination Enable
    • Synchronous Fixed-Frequency PWM
      Controller Operating at 3 MHz With 0% to
      99.5% Duty Cycle
    • Safety Timer With Reset Control
    • Reverse Leakage Protection Prevents Battery
      Drainage
    • Thermal Regulation and Protection
    • Input/Output Overvoltage Protection
    • Automatic Charging
    • Boost Mode Operation for USB OTG
      • Input Voltage Range (VSYS): 2.5 V to
        4.5 V
      • Output Voltage for VBUS: 5 V
  • WLED Driver
    • 35-V Open LED Protection for Up to 8 LEDs
    • 200-mV Reference Voltage With ±2%
      Accuracy
    • Built-In Soft Start for WLED Boost
    • Up to 90% Efficiency
  • Current Shunt Monitor
    • Fixed Gain of 25 V/V
    • Input Referred Offset Voltage Less Than
      ±40 μV Typical Enables Use of Shunt
      Resistors as Low as 20 mΩ
    • Buffered Reference Voltage
  • Package
    • 36-Ball, 0.4-mm Pitch DSBGA Package
  • APPLICATIONS
    • Mobile Phones and Smart Phones
    • MP3 Players
    • Portable Navigation Devices
    • Handheld Devices
All other trademarks are the property of their respective owners
The TPS65200 device integrates a high-efficiency, USB-friendly switched-mode charger with OTG support for single-cell Li-ion and Li-polymer batteries, D+D? detection, a 50-mA fixed-voltage LDO, a high-efficiency WLED boost converter, and high-accuracy current-shunt monitor into a single chip.
The TPS65200 comes in a tiny, 2.8-mm × 2.6-mm, 36-pin, 0.4-mm pitch die size ball grid array (DSBGA).
