公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
一个降压直流/直流转换器和五个线性稳压器,具有 I2C 兼容接口
Regulated outputs (#) 6
Vin (Min) (V) 2.7
Vin (Max) (V) 4.5
Iout (Max) (A) 0.4
Rating Catalog
LDO 5
Iq (Typ) (mA) 0.7
Features Dynamic Voltage Scaling, I2C Control
Shutdown current (ISD) (Typ) (uA) 0.7
Switching frequency (Typ) (kHz) 2000
Configurability Software configurable
  • 5 Low Noise LDO’s for up to 300 mA
  • One High-Efficiency Synchronous Magnetic Buck Regulator, IOUT 400 mA
    • High Efficiency PFM Mode @Low IOUT
    • Auto Mode PFM/PWM Switch
    • Low Inductance 2.2 μH @ 2 MHz Clock
    • Dynamic Voltage Scale Control
  • I2C-Compatible Interface for the Controlling of Internal Registers
  • 20-Bump 2.5 x 2.0 mm DSBGA Package
Key Specifications
  • Programmable Vout from 0.8V to 2.3V on DC-DC
  • Automatic Soft Start on DC-DC
  • 200 mV Typ Dropout Voltage at 300 mA on LDO’s
  • 2% (Typ) Output Voltage Accuracy on LDO’s
All trademarks are the property of their respective owners.
The LP8720 is a multi-function, programmable Power Management Unit, optimized for sub block power requirement solution. This device integrates one highly efficient 400 mA step-down DC-DC converter with Dynamic Voltage Scale (DVS), five low noise low dropout (LDO) voltage regulators and a 400 KHz I2C-compatible interface to allow a host controller access to the internal control registers of the LP8720. The LP8720 additionally features programmable power-on sequencing.
LDO regulators provide high PSRR and low noise ideally suited for supplying power to both analog and digital loads. The package will be the smallest 2.5 mm x 2.0 mm DSBGA 20-bump package.
