公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
支持 15V 输入电压、工作温度范围为 -40°C 至 105 °C 的 50V、7 通道达林顿晶体管阵列
Drivers per package 7
Switching voltage (Max) (V) 50
Output voltage (Max) (V) 50
Peak output current (mA) 500
Delay time (Typ) (ns) 250
Input compatibility CMOS, TTL
Vol @ lowest spec current (Typ) (mV) 900
Iout/ch (Max) (mA) 500
Iout_off (Typ) (uA) 50
Rating Catalog
  • 500-mA-Rated Collector Current (Single Output)
  • High-Voltage Outputs . . . 50 V
  • Output Clamp Diodes
  • Inputs Compatible With Various Types of Logic
  • Relay-Driver Applications
The ULN2004AI is a high-voltage, high-current Darlington transistor array. This device consists of seven npn Darlington pairs that feature high-voltage outputs with common-cathode clamp diodes for switching inductive loads. The collector-current rating of a single Darlington pair is 500 mA. The Darlington pairs can be paralleled for higher-current capability. Applications include relay drivers, hammer drivers, lamp drivers, display drivers (LED and gas discharge), line drivers, and logic buffers.
The ULN2004AI has a 10.5-k. series base resistor for each Darlington pair for operation directly with TTL or 5-V CMOS devices.
