公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
汽车类低静态电流可编程延迟监控器
Number of supplies monitored 1
Threshold voltage 1 (Typ) (V) Adjustable, 1.12, 1.16, 1.4, 1.67, 2.79, 3.07, 4.65
Features Manual reset capable
Reset threshold accuracy (%) 2
Output driver type/reset output Active-low, Open-drain
Time delay (ms) Programmable
TI functional safety category Functional Safety-Capable
Rating Automotive
Watchdog timer WDI (sec) None
Operating temperature range (C) -40 to 125
  • Qualified for Automotive Applications
  • Power-On Reset Generator With Adjustable Delay Time: 1.25ms to 10s
  • Very Low Quiescent Current: 2.4μA Typical
  • High Threshold Accuracy: 0.5% Typical
  • Fixed Threshold Voltages for Standard Voltage Rails From 1.2V to 5V and Adjustable Voltage Down to 0.4V Are Available
  • Manual Reset (MR) Input
  • Open-Drain RESET Output
  • Temperature Range: –40°C to +125°C
  • Small SOT-23 Package and WSON Package (TPS3808G01QDRVRQ1 only)
The TPS3808Gxx-Q1 microprocessor supervisory circuits monitor system voltages from 0.4V to 5V, asserting an open-drain RESET signal when the SENSE voltage drops below a preset threshold or when the manual reset (MR) pin drops to a logic low. The RESET output remains low for the user-adjustable delay time after the SENSE voltage and MR return above their thresholds.
The TPS3808Gxx-Q1 device uses a precision reference to achieve 0.5% threshold accuracy for VIT ≤ 3.3 V. The reset delay time can be set to 20ms by disconnecting the CT pin, 300ms by connecting the CT pin to VDD using a resistor, or can be user-adjusted from 1.25ms to 10s by connecting the CT pin to an external capacitor. The TPS3808Gxx-Q1 has a very low typical quiescent current of 2.4μA, so it is well suited for battery-powered applications. The device is available in a small SOT-23 package (one option available in WSON) and is fully specified over a temperature range of –40°C to +125°C (TJ).
For more information about TI?s voltage supervisor portfolio, visit the Supervisor and Reset IC Overview Page page.
