公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
1.7 - 6.0GHz 宽带集成直接降压转换接收器
BB BW LP filter (Min) (MHz) 0.7
BB BW LP filter (Max) (MHz) 15
Supply voltage (Typ) (V) 5
IIP3 (Typ) (dBm) 22
IIP2 (Typ) (dBm) 52
Frequency (Typ) 1.7 - 6.0 GHz
Rating Catalog
  • Frequency Range: 1700 MHz to 6000 MHz
  • Integrated Baseband Programmable-Gain Amplifier
  • On-Chip Programmable Baseband Filter
  • High Out-of-Band IP3: 22 dBm at 3550 MHz
  • High Out-of-Band IP2: 52 dBm at 3550 MHz
  • Hardware and Software Power Down
  • Three-Wire Serial Interface
  • Single Supply: 4.5-V to 5.5-V Operation
  • Silicon Germanium Technology
  • APPLICATIONS
    • Multicarrier Wireless Infrastructure
    • WiMAX
    • High-Linearity Direct-Downconversion Receiver
    • LTE (Long Term Evolution)
All trademarks are the property of their respective owners.
The TRF371135 is a highly linear and integrated direct-conversion quadrature demodulator. The TRF371135 integrates balanced I and Q mixers, LO buffers, and phase splitters to convert an RF signal directly to I and Q baseband. The on-chip programmable-gain amplifiers allow adjustment of the output signal level without the need for external variable-gain (attenuator) devices. The TRF371135 integrates programmable baseband low-pass filters that attenuate nearby interference, eliminating the need for an external baseband filter.
Housed in a 7-mm × 7-mm QFN package, the TRF371135 provides the smallest and most integrated receiver solution available for high-performance equipment.
