公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
0.4GHz 至 4.0GHz 正交调制器,1.7V 共模电压
Frequency (Min) (MHz) 400
Frequency (Max) (MHz) 4000
I/Q input common-mode voltage (Typ) 1.7
PLL/VCO No
P1dB (Typ) (dBm) 12
Output IP3 (Typ) (dBm) 26.5
Noise floor (Typ) (dBm/Hz) -163
Unadjusted carrier suppression (Typ) (dBm) -40
Unadjusted sideband suppression (Typ) (dBc) -45
Rating Catalog
  • 76-dBc Single-Carrier WCDMA ACPR at –8 dBm Channel Power
  • Low Noise Floor: –163 dBm/Hz
  • OIP3 of 26.5 dBm
  • P1dB of 12 dBm
  • Unadjusted Carrier Feedthrough of –40 dBm
  • Unadjusted Side-Band Suppression of –45 dBc
  • Single Supply: 4.5-V–5.5-V Operation
  • Silicon Germanium Technology
  • 1.7-V CM at I, Q Baseband Inputs
  • APPLICATIONS
    • Cellular Base Station Transceiver
    • CDMA: IS95, UMTS, CDMA2000, TD-SCDMA
    • TDMA: GSM, IS-136, EDGE/UWC-136
    • Multicarrier GSM
    • WiMAX: 802.16d/e
    • 3GPP: LTE
    • Wireless MAN Wideband Transceivers
The TRF370317 is a low-noise direct quadrature modulator, capable of converting complex modulated signals from baseband or IF directly up to RF. The TRF370317 is a high-performance, superior-linearity device that is ideal to RF frequencies of 400 MHz through 4 GHz. The modulator is implemented as a double-balanced mixer. The RF output block consists of a differential to single-ended converter and an RF amplifier capable of driving a single-ended 50- load without any need of external components. The TRF370317 requires a 1.7-V common-mode voltage for optimum linearity performance.
