Current consumption (mA) | 98 |
Frequency (Min) (MHz) | 2400 |
Frequency (Max) (MHz) | 2483.5 |
Gain (Typ) (dB) | 25 |
Impedance match (Ohms) | 50 |
Noise figure (Typ) (dB) | 3.1 |
Number of channels (#) | 1 |
Operating temperature range (C) | -40 to 85 |
Output enable | Yes |
P1dB (Typ) (dBm) | 17 |
Type | PA Driver |
Rating | Catalog |
Power down current | Yes |
- Low Cost and Small Package
- Very Few External Components
- 2.0-V to 3.6-V Operation
- Less Than 1-μA Current Consumption in Power Down Mode
- Low Transmit Current Consumption
- 98 mA at 3 V for +20.7 dBm Out (PAE = 40%)
- RoHS Compliant 3- × 3-mm QFN-16 Package
CC2595 is a PA solution that extends the range of any Zigbee or Bluetooth transceiver. It is a cost-effective and high performance RF front end for low-power and low-voltage wireless applications in the 2.4-GHz band. Its single-ended RF input and output make it compatible with any manufacturer’s transceiver if appropriate external parts are used. When a transmit/receive (T/R) switch and a balun are used, it can interface with existing and future CC24XX and CC25XX transceiver products. CC2595 extends the link budget by providing a power amplifier for improved output power. It is highly effective for high (+20 dBm) output power making it suitable for battery-operated systems. CC2595 contains PA and RF-matching for simple design of high performance wireless applications. It is packaged in a 3- × 3-mm, 16-lead QFN package with exposed paddle.
