Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 4.75 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 5.25 |
BW @ Acl (MHz) | 2400 |
Acl, min spec gain (V/V) | 2 |
Slew rate (Typ) (V/us) | 3200 |
Architecture | Fully Differential ADC Driver, Fixed Gain/Buffer, Bipolar |
Vn at flatband (Typ) (nV/rtHz) | 1.7 |
Iq per channel (Typ) (mA) | 100 |
Rail-to-rail | No |
Vos (offset voltage @ 25 C) (Max) (mV) | 5 |
Operating temperature range (C) | -40 to 85 |
Output current (Typ) (mA) | 80 |
2nd harmonic (dBc) | 87 |
3rd harmonic (dBc) | 103 |
Frequency of harmonic distortion measurement (MHz) | 10 |
GBW (Typ) (MHz) | 2400 |
Input bias current (Max) (pA) | 400000000 |
Features | Shutdown, On chip gain resistors |
CMRR (Typ) (dB) | 60 |
Rating | Catalog |
- 2.4GHz Bandwidth
- 3100V/μs Slew Rate, VOUT =2V Step
- Fixed Voltage Gain: +6dB
- IMD3: –107dBc, VOUT = 2VPP, RL = 400Ω,
f = 100MHz - OIP3: 48dBm, f = 100MHz
- Noise Figure: 11dB, f = 100MHz
The THS770006 is a fixed-gain of +6dB, wideband, fully-differential amplifier designed and optimized specifically for driving 16-bit analog-to-digital converters (ADCs) at input frequencies up to 130MHz, and 14-bit ADCs at input frequencies up to 200MHz. This device provides high bandwidth, high-voltage output with low distortion and low noise, critical in high-speed data acquisition systems that require very high dynamic range, such as wireless base stations and test and measurement applications. This device also makes an excellent differential amplifier for general-purpose, high-speed differential signal chain and short line driver applications.
The THS770006 operates on a nominal +5V single supply, offers very fast, 7.5ns maximum recovery time from overdrive conditions, and has a power-down mode for power saving. The THS770006 is offered in a Pb-free (RoHS compliant) and green, QFN-24 thermally-enhanced package. It is characterized for operation over the industrial temperature range of –40°C to +85°C.
