Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 4.7 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 5.25 |
BW @ Acl (MHz) | 2800 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 6200 |
Architecture | Fully Differential ADC Driver, Current FB, Bipolar |
Vn at flatband (Typ) (nV/rtHz) | 0.9 |
Iq per channel (Typ) (mA) | 52 |
Rail-to-rail | No |
Vos (offset voltage @ 25 C) (Max) (mV) | 3 |
Operating temperature range (C) | -40 to 125 |
Output current (Typ) (mA) | 150 |
2nd harmonic (dBc) | 68 |
3rd harmonic (dBc) | 70 |
Frequency of harmonic distortion measurement (MHz) | 250 |
GBW (Typ) (MHz) | 2500 |
Input bias current (Max) (pA) | 8000000 |
Features | Shutdown |
CMRR (Typ) (dB) | 83 |
Rating | Catalog |
- Small-Signal Bandwidth 2.8 GHz
- 2 VPP Large-Signal Bandwidth 1.8 GHz
- 0.1 dB Gain Flatness 830 MHz
- OIP3 at 150 MHz 46.5 dBm
- HD2/HD3 at 75 MHz –96 / –97 dBc
- Input Noise Voltage 0.9 nV/√Hz
- Input Noise Current 11 pA/√Hz
- Slew Rate 6200 V/μs
- Power 260 mW
- Typical Supply Current 52 mA
- 14-Lead UQFN Package
The LMH6554 device is a high-performance fully differential amplifier designed to provide the exceptional signal fidelity and wide large-signal bandwidth necessary for driving 8- to 16-bit high-speed data acquisition systems. Using TI?s proprietary differential current mode input stage architecture, the LMH6554 has unity gain, small-signal bandwidth of 2.8 GHz and allows operation at gains greater than unity without sacrificing response flatness, bandwidth, harmonic distortion, or output noise performance.
The low-impedance differential output of the device is designed to drive ADC inputs and any intermediate filter stage. The LMH6554 delivers 16-bit linearity up to 75 MHz when driving 2-V peak-to-peak into loads as low as 200 Ω.
The LMH6554 is fabricated in TI?s advanced complementary BiCMOS process and is available in a space-saving 14-lead UQFN package for higher performance.
