Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 3.75 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 5.25 |
BW @ Acl (MHz) | 1100 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 5100 |
Architecture | Fully Differential ADC Driver, Bipolar |
Vn at flatband (Typ) (nV/rtHz) | 2 |
Iq per channel (Typ) (mA) | 39.2 |
Rail-to-rail | In to V- |
Vos (offset voltage @ 25 C) (Max) (mV) | 4 |
Operating temperature range (C) | -55 to 125, 25 to 25 |
Approx. price (US$) | 943.95 | 1ku |
Output current (Typ) (mA) | 96 |
2nd harmonic (dBc) | 106 |
3rd harmonic (dBc) | 108 |
Frequency of harmonic distortion measurement (MHz) | 10 |
GBW (Typ) (MHz) | 3000 |
Input bias current (Max) (pA) | 15500000 |
Features | Shutdown |
CMRR (Typ) (dB) | 80 |
Rating | Space |
- Fully Differential Architecture
- Common-Mode Input Range Includes Negative Rail
- Minimum Gain of 2 V/V (6 dB)
- Bandwidth: 1.1 GHz (Gain = 6 dB)
- Slew Rate: 5100 V/μs
- 1% Settling Time: 5.5 ns
- HD2: -76 dBc at 70 MHz
- HD3: -88 dBc at 70 MHz
- OIP2: 84 dBm at 70 MHz
- OIP3: 42 dBm at 70 MHz
- Input Voltage Noise: 2 nV/ System, G = 6 dB)
- Output Common-Mode Control
- 5 V Power Supply Current: 39.2 mA
- Power-Down Capability: 0.65 mA
- Rad-Tolerant: 150 kRad (Si) TID
- QML-V Qualified, SMD 5962-07222
- APPLICATIONS
- 5 V Data-Acquisition Systems
- High Linearity ADC Amplifier
- Wireless Communication
- Medical Imaging
- Test and Measurement
The THS4511 is a fully differential operational amplifier designed for single-supply 5 V data-acquisition systems. It has very low noise at 2 nV/ load. Slew rate is very high at 5100 V/μs and with settling time of 5.5 ns to 1% (2 V step) it is ideal for pulsed applications. It is designed for minimum gain of 6 dB.
To allow for dc coupling to ADCs, its unique output common-mode control circuit maintains the output common-mode voltage within 5 mV offset (typical) from the set voltage, when set within ±0.5 V of mid-supply. The common-mode set point is set to mid-supply by internal circuitry, which may be over-driven from an external source.
The THS4511 is a high-performance amplifier that has been optimized for use in 5 V single-supply data acquisition systems. The output has been optimized for best performance with its common-mode voltages set to mid-supply, and the input has been optimized for performance over a wide range of common-mode input voltages. High performance at a low power-supply voltage enables single-supply 5 V data-acquisition systems while minimizing component count.
The THS4511 is offered in a 16-pin ceramic flatpack package (W), and is characterized for operation over the full military temperature range from -55°C to 125°C.
