Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 3.75 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 5.25 |
BW @ Acl (MHz) | 1600 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 4900 |
Architecture | Fully Differential ADC Driver, Bipolar |
Vn at flatband (Typ) (nV/rtHz) | 2 |
Iq per channel (Typ) (mA) | 39.2 |
Rail-to-rail | In to V- |
Vos (offset voltage @ 25 C) (Max) (mV) | 4 |
Operating temperature range (C) | -40 to 85 |
Output current (Typ) (mA) | 96 |
2nd harmonic (dBc) | 117 |
3rd harmonic (dBc) | 106 |
Frequency of harmonic distortion measurement (MHz) | 10 |
GBW (Typ) (MHz) | 2000 |
Input bias current (Max) (pA) | 15500000 |
Features | Shutdown |
CMRR (Typ) (dB) | 90 |
Rating | Catalog |
- Fully-Differential Architecture
- Common-Mode Input Range Includes the Negative Rail
- Unity-Gain Stable
- Bandwidth: 1.6 GHz (Gain = 0 dB)
- Slew Rate: 4900 V/μs
- 1% Settling Time: 3.3 ns
- HD2: –72 dBc at 70 MHz
- HD3: –87 dBc at 70 MHz
- OIP2: 76 dBm at 70 MHz
- OIP3: 42 dBm at 70 MHz
- Input Voltage Noise: 2 nV/√Hz (f > 10 MHz)
- Noise Figure: 21.8 dB (50- System, G=6dB)
- Output Common-Mode Control
- 5-V Power-Supply Current: 39.2 mA
- Power-Down Capability: 0.65 mA
- APPLICATIONS
- 5-V Data-Acquisition Systems
- High Linearity ADC Amplifiers
- Wireless Communication
- Medical Imaging
- Test and Measurement
The THS4511 is a wideband, fully-differential operational amplifier designed for single-supply 5-V data-acquisition systems. It has very low noise at 2 nV/√Hz, and extremely low harmonic distortion of –72 dBc HD2 and –87 dBc HD3 at 70 MHz with 2 VPP, G= 0 dB, and 200- load. Slew rate is very high at 4900 Vμs and with settling time of 3.3 ns to 1% (2 V step) it is ideal for pulsed applications. It is designed for minimum gain of 0 dB.
To allow for dc coupling to analog-to-digital converters (ADCs), its unique output common-mode control circuit maintains the output common-mode voltage within 5-mV offset (typical) from the set voltage, when set within ±0.5 V of midsupply. The common-mode set point is set to midsupply by internal circuitry, which may be over-driven from an external source.
The THS4511 is a high-performance amplifier that has been optimized for use in 5-V single-supply data acquisition systems. The output has been optimized for best performance with its common-mode voltages set to midsupply, and the input has been optimized for performance over a wide range of common-mode input voltages. High performance at a low power-supply voltage enables single-supply 5-V data-acquisition systems while minimizing component count.
The THS4511 is offered in a quad, 16-pin leadless QFN package (RGT), and is characterized for operation over the full industrial temperature range from –40°C to +85°C.
